Summit Stars
The Summit Stars are heavy wheels. They are cast aluminum. Over 20lbs. Probably closer to 25. If you just want the look, great. But if you are trying to get a better ET then look elsewhere. I was thinking of using their 17x7 wheel in the front for a good street skinny that clears the brakes and using Weld Prostars in the rear since they are really light. Then putting Weld skinnies on for the track.
Good Luck.
Good Luck.
Good Luck.
Good Luck.
I have some Front Prostars sitting in my spare room. I'll take out out of the box and weigh it then dismount the Summit Star front and weigh that when I stick my Fikse's back on.
Nowhere near 25 lbs. They are only about 5 lbs heavier per wheel. So if a Prostar weighs 10-11 lbs then the Summit would be 15-16 and if the rears are 14-15 then the Summit would be 19-20.
The one where your car idles very rough, almost has a miss, primaries already turning blue, tightened down all flange bolts, no exhaust leak, can't figure out what the hell it is, gallon of gasoline with a match and collect insurance money sound.
yeah, thats about right.
i had to grind calipers just to clear wheel weights then gave up and just ran them unbalanced. Downside to the summit stars is they do not use a shank style lug. I run summit stars, but once I start going faster they are going off and putting something else on the car
