Billet Specialties Streetlites w/Spacers. Pics Inside
A few people have been asking me how my 15x4" Streetlites fit and if I had to grind my calipers. When I mounted my Streetlites I opted to run a 1/4" spacer so I didn't have to grind my powdercoated calipers. Here are some pics of the clearance. They are a tight fit but they clear the calipers with no problems. I hope this info and these pics help and sorry about the rainy pics. My car sits outside when it's out of storage.
Here are the pics you requested. The front wheel specs are 15x4" with a 1.625" backspacing and I'm running a 1/4" spacer from Billet specialties. I bought everything from Dragwheelz.com. I believe his name was Jason and he was a great guy to deal with. Absolutely top notch products and service. I also have more pics of the wheels on the car in another thread I posted in this section.
I originally went with the longer ARP studs on the rear because I twisted a set of Moser 1/2" studs and I wanted some extra strength. I then decided to run them on the front also because I was running a spacer. To answer your question, yes, they are a bit excessive but I felt it was better to be safe then sorry.
can u post up a pic of the whole car for me?
i have chrome Zr1 17's now and im eather going to go with 18 front and 19 rear wheels or a drag set up like yours.
i also seen some where that they make those wheels in a 17in wheel.
I have already got them wet and dirty. I washed the car and wheels at the car wash, wiped them off with a microfiber towel, and cleaned them up with a little Mother's Billet Polish. They looked good as new. When I detail the car I'll take them off and work on them a little more but they clean up better than I expected for just a simple wash.
DTB: That sure is a tight squeeze that you got going on there. Just wanted to ask you a question. I assume that you are still running the factory LS1 brakes up front, and you already said that the 15x4's you have now required no grinding only a spacer. I would like to put a set of 15's up front on my 3rd gen carmaro but I have the baer brakes up front that *supposedly* require 17 inch wheels. Well, I put a 16 inch wheel from a 91 camaro on the front, and I have about 1/2 inch of caliper to wheel clearance with the 16. On my 98 T/A I have the factory 16's on it and the wheel to caliper clearance is tight like what your picture shows. Do you think that your Billet Specialites 15x4's would fit on my camaro? Are they designed to have more clearance than other standard 15 inch wheels? Thanks for any info you might have. BTW, your setup looks killer!! Have fun with it!
15x4, 1625, backspacing, billet, cleaning, egr, il, ottawa, pic, pics, schaumburg, sebring, spacers, specialites, specialties, spintech, valve
