street lite fitment
even if the calipers are ground down to fit weld prostars? ordered a set from summit last night, didn,t know that they even made a 15 x 10 that would fir the f body breaks untill after i bought them. hope they will clear. i'll let a know either way.
I fitted a Lt1 car with a narrowed rearend and put a 5.5" wheel on it and it fit without grinding.
With a Ls1 rear caliper The grinding you have to do you might as well just remove your calipers to fit the standard wheel. This is 1 of the reasons the F body Spec wheel was produced.
The fronts require Minimal grinding to fit.
