Slicks on a 95 Camaro?
Old 06-12-2009, 06:02 PM
Anthony0908's Avatar
Default Slicks on a 95 Camaro?
Will 305 45 15 size tires fit a stock camaro? if not what has to be done?
Old 06-12-2009, 06:36 PM
tspence45's Avatar
They should fit. They're roughly the same height as stock tires. You just may have to worry about a little inner fender rub, depending on the backspacing of your rims. You could either BFH the inner fenders, or run a small spacer.
Old 06-12-2009, 06:48 PM
I love BFhs lol
They would go on the stock rims just curious because there taller and wider.
Old 06-12-2009, 06:52 PM
keith_AE2010's Avatar
A 15 inch tire on a 16 inch wheel?
Old 06-12-2009, 06:59 PM
15 the tire goes to a 15 inch rim.
Old 06-12-2009, 07:29 PM
You just said they were gonna go on the stock rims.
Old 06-12-2009, 07:51 PM
Stockers are not 15? i feel stupid now.
Old 06-12-2009, 07:55 PM
Post a pic. You could have 16s or 17s depending on year, options, things. But, the base was a 16 X 8. In which case you can fit a big slick on, like 26x10.5 or sox16.
Old 06-12-2009, 07:56 PM
Or just go outside and look at your tires. The last number on the size should be 16.
Quick Reply: Slicks on a 95 Camaro?
