02 trans am with c5 z06 wheels, fitment question
Old 07-13-2009, 08:49 PM
plaf713's Avatar
Default 02 trans am with c5 z06 wheels, fitment question
my friend wants to put on 19x9.5 and 19x11 c5 z06 wheels on his trans am, the offsets that i have found are 56mm for the 9.5 and 64mm for the 11, just wondering if that sound correct or not, also if anyone has any pictures of that big of a wheel on an fbody.
thanks in advance
Old 07-13-2009, 09:09 PM
plaf713's Avatar
actually the fronts are 54 mm
Old 07-14-2009, 08:24 AM
Xsta Z 28's Avatar
Never heard of 19" diameter C5 wheels . . .
The sizes you mention, fronts are fine, rear will require a spacer.
Old 07-14-2009, 10:42 AM
plaf713's Avatar
ive never heard of that size either, only 19x10s i have found for the c5 z06 wheel, im a noob to wheels so what kind of spacer would be used for the rear wheels
Old 07-14-2009, 11:08 AM
Xsta Z 28's Avatar
About 14 mm . . . . to net you an assumed / approximate final offset of ~ 50 mm.
Quick Reply: 02 trans am with c5 z06 wheels, fitment question
