will 18/19 wheels off a c6 fit a f-body
Old 08-24-2009, 01:49 PM
johnster's Avatar
Default will 18/19 wheels off a c6 fit a f-body
seens like i read somewhere that they would fit???
i no somebody on here will no thanks
Old 08-24-2009, 09:05 PM
firstinlastout86's Avatar
yes you will need a spacer for the 19's just do a search.....
Old 08-24-2009, 09:25 PM
DriftR's Avatar
Fronts bolt right up and rear needs adapter spacer (for OEM C6's).
I have 1" adapter in the front with studs ground down 1/8 for clearence and 1.25 adapter bolted in the rear which puts all the wheels right at the inside edge of the fenders.
Old 08-24-2009, 09:31 PM
johnster's Avatar
thanks guys
driftR do you have any close up [ics of the car???
Old 08-25-2009, 12:35 AM
DriftR's Avatar
Originally Posted by johnster
thanks guys
I don't have much with the C6's, they're one of three sets of wheels that get swapped around on the T/A. They were on there while I was polishing the lips on the wheels in my sig.
Old 08-25-2009, 11:07 PM
DriftR's Avatar
Here's some for ya
Old 08-26-2009, 03:18 PM
95LT1_white's Avatar
yuppp... i did it...
http://i883.photobucket.com/albums/a...33_3131744.jpg
http://i883.photobucket.com/albums/a...33_3131743.jpg
http://i883.photobucket.com/albums/a...33_3131738.jpg
Old 08-26-2009, 05:45 PM
LS1Tech Platinum Sponsor
OEWheelsLance's Avatar
Nice ride DriftR
Old 08-26-2009, 07:04 PM
LS1ne's Avatar
niiiccce. hey what size rear tires come stock on c6 wheels??
Old 08-26-2009, 08:13 PM
DriftR's Avatar
Originally Posted by OEWheelsLance
Nice ride DriftR
much appreciated, Thanks!
285/35/19, I believe.
Old 08-30-2009, 08:58 AM
Slash8915's Avatar
I have the 18/19 set up. I just used a 1.25" adapter in the rear. Although, now, every time i brake my ABS kicks in and it makes it VERY hard to drive everywhere.
Old 08-30-2009, 09:22 AM
littlehery's Avatar
do u know where i can buy 1.25 spacers? im purchasing a 18/19 setup for my 96 red camaro it will look exactly like driftRs car and by the way is pretty nice
Old 08-30-2009, 10:49 PM
DriftR's Avatar
If you search you may find negative "china junk" posts about buying ebay spacers on the forum however I purchased 1" and 1.25" lug centric Adapters (5x4.75 - 12mmx1.5 stud) for my OEM C6 wheels on Ebay.
Very simply, they are 6061-T6 aluminum turned to thickness on a laithe and then drilled and counterbored in a vertical mill. I measured mine and the tolerances are very good (within a couple thousanths +/- .0015).
Most importantly they come pressed with 10.9 Metric studs which is the highest strength SAE equivalent stud and lugs nuts.
You can spend more for H&R and the rest but you don't have to IMO!
Quick Reply: will 18/19 wheels off a c6 fit a f-body
