Offset Guru's Please
Maybe its not that hard of a question, I just couldnt seem to find the data. I have a rearend thats 2 inches shorter than stock and Im looking for what offset I need for a 17" or 18" wheel with no spacer if possible. Currently using the stock wheels with a 1" spacer.
I dont know why we dont have more offset info, you should see what the rx7,240, and 350z guys fit onto there cars...
There rim selection and deep dish offsets are badass
i have my rear shortened 1" per side so same as u and have the same problem.
if you go with a 9.5 wide wheel and a 275 tire, your offset can be as high as ~+40-45. you might be able to go more but it gets riskier.
i have rpm 505 wheels(+38) that are 19x9.5 on vredestein 275/30/19 tires and they fit fine with the bfh. i cut my lca's where they curve to gain more clearance. so for sure a 38mm or less on a 9.5 wheel will work.
my original plan was to run 20x10 rpm 505's that have a +10mm offset but i changed my mind on trying to launch on 20's. so if you're ok with a 20x10, 505's have the offset for you.
if you go above 9.5 wide wheels, it gets troubling.
i like tucked wheels so i'm in the range of +15 to +30mm. hard to find wheels that are 11" wide and have the 0-30mm offset for our cars.
something that might work are the zr1 17x11 +36 offset with maybe a ~1/4" spacer.
i can get my ttm 17X10.5 +44 wheels and sumi 315's to fit but there is work and offset lca's are good to have. i had to do a lot of bfh and trim a chunk off the lca's. it's also centered with adjustable panhard. i used a 6mm spacer to gain more clearance from the lca. it barely clears but enough for daily driving...not too sure about launching hard without the offset lca's.
otherwise offset lca's and a minitub should enable you to run what stock length rear ends are running on here and you'll still be tucking 1" or so of the tire.
let me know what you find.
