Old 04-26-2016, 02:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Tire Repair and Maintenance
Print Wikipost
Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!!
Old 07-27-2004, 07:56 AM
  #61
black 2001Vette,Nightmare's Avatar
What is the factory offset on my Y2K thin spokes? I want to take them off and install them on my 2000 SS Camaro...will they fit at factory ride height, with the stock 275/40-18? Thanks...
Last edited by black 2001Vette,Nightmare; 07-27-2004 at 07:59 AM. Reason: Omission
black 2001Vette,Nightmare is offline
Old 07-27-2004, 10:08 AM
  #62
Todd@AZPowerAndSound's Avatar
17x8.5 +56, looks kinda small on a fbody
18x9.5 +61, too high of an offset for a fbody
Replicas work better.
Todd@AZPowerAndSound is offline
Old 07-27-2004, 03:00 PM
  #63
FenixSS's Avatar
Originally Posted by Xsta Z 28
The inner wheel well may need the BFH on the back, but no fender lip rolling.
Is that with either the 9.5 or 10.5 all around? Or both? And the tire set up of 285x35x18 ok?
FenixSS is offline
Old 07-27-2004, 03:34 PM
  #64
DARN! I just bought a set of Z06 Motorsports with tires, pkg. from you guys, and was hoping to have a place to put these!
Well...crap, I guess I'll have to try and sell them now. Hoping to avoid that ordeal. Oh well...
Thanks for your help.
Old 07-27-2004, 04:12 PM
  #65
Xsta Z 28's Avatar
Possibly both, more than likely not, the 10.5's for sure.
Xsta Z 28 is offline
Old 07-29-2004, 08:10 PM
  #66
Ferocity02's Avatar
Here is my set-up:
-18x9.5 Chrome Z06 wheels on all four corners
-285/35-18 Goodyear Eagle F1 tires on all corners
-No rubbing so far, at least 1" of clearence for rear tires
-54mm offset
I will post pics later.
Ferocity02 is offline
Old 07-30-2004, 08:44 AM
  #67
Xsta Z 28's Avatar
Originally Posted by Ferocity02
Here is my set-up:
-54mm offset
Good to hear!
Old 08-06-2004, 11:14 AM
  #68
tump's Avatar
has anyone tried Y2K vette rims 18 by 9.5 and 18 by 10.5 with 275/35/18, 315/30/18? I really want to know it they will fit on a Trans/am the 315 is causing me concern. It will look great,if it fits.I am going to order the wheels,but am concerned.
tump is offline
Old 08-09-2004, 08:33 AM
  #69
Xsta Z 28's Avatar
Well your front wheel tire is OK, the rear, 315, will be tough, especially with the limited offests of the Vette wheels, and if you are lowered . . . One thing in your favor, you havea Firebird, wich has ever so slightly wider rear quarters . . .
Old 08-17-2004, 10:20 AM
  #70
HOSS99's Avatar
What are the wheel sizes and offsets of the factory OEM ZO6 Rims? Will they fit an f-body?
HOSS99 is offline
Old 08-17-2004, 10:23 AM
  #71
OEM Z06 fronts are fine, rears have too high of an offset...+61
Old 08-17-2004, 11:30 PM
  #72
jeeves744's Avatar
im going to be buying some C5 replica wheels. 17x9.5 with 56mm offset. What is the widest tire i can fit on the front and back of my 2000 TA?
jeeves744 is offline
Old 08-18-2004, 04:06 AM
  #73
FenixSS's Avatar
Todd, you guys still have Black Z06 motorsports in stock, especially in a 50-54mm offset? I can't find them when I do a search.
FenixSS is offline
Old 08-18-2004, 07:55 AM
  #74
Xsta Z 28's Avatar
285/40ZR17
  #75
Xsta Z 28's Avatar
Please e-mail or call Todd directly, he does not visit the forum often . . .
Old 08-23-2004, 11:17 AM
  #76
HOSS99's Avatar
Which is the better offset for 18x10.5 Z06 replicas...50mm or 53mm? I plan to use a 305/35 Nitto DR in the rear. Is that tire to tall to fit good?
HOSS99 is offline
Old 08-23-2004, 11:30 AM
  #77
Xsta Z 28's Avatar
If you can get 50mm, you will be happier -
Just remember the smaller the offset the further the wheel moved outward, 38mm is the absolute smallest offset I would ever recommend.
Also please note, if you are lowered the smaller offset increases the possibility of the tire contacting the wheel well lip.
Old 08-23-2004, 11:44 AM
  #78
HOSS99's Avatar
Why?
How I understand it as of now - The 50mm will move the wheel closer to the lip, while the 53mm will move the wheel away from the lip, but closer to the inner fender wheel wheel? So wouldn't the 53mm be better, or does that hit the inner fender wheel wheel?
HOSS99 is offline
Old 08-23-2004, 01:41 PM
  #79
B00SS's Avatar
I'm sorry, I don't even know what the stock offset is, so I will just ask. My friend is trading in a ’93 vette. It has the 285/40/17’s I have an opportunity to get these for nothing. We will just swap before he trades. Will these fit my stock chrome wheels from my SS and will my 275/40/17’s fit his stock wheels? I really don’t want to take a hammer to my car. I need to move on this deal quick, so any help would be greatly appreciated.
B00SS is offline
Old 08-23-2004, 01:49 PM
  #80
Xsta Z 28's Avatar
Originally Posted by HOSS99
Why?
Agressive looks, but that is my opinion, I was always dissappointed with my Z06 wheels, because they were too tucked into the wheel wells . . .
How I understand it as of now - The 50mm will move the wheel closer to the lip, . . .
Yes
. . . while the 53mm will move the wheel away from the lip, but closer to the inner fender wheel wheel?
Yes, but a difference of 3mm isn't a whole lot, 1/8" . . . so it too will more than likely contact the wheel well lip, but gives you an 1/8" more "room"
Either will honestly work well. The 58mm 10.5" wheel, which is pretty common, will rub the inner wheel well, the others, likey will not, but in turn increase the possibility of the tire contacting the wheel well lip. My 38 mm offset 10.5" wheel w/ 295/35ZR18's only contact the wheel well lip on the passenger side of the car, over some bumps, lowered 1" . . . just FYI
Quick Reply: Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!!
