What offset to be flush on Camaro?
Old 09-27-2010, 06:54 PM
R1ch's Avatar
Default What offset to be flush on Camaro?
I have OEM C5 Z06 wheels on my car and I believe the rears are +58mm offset. The thing is they don't come anywhere NEAR flush with the rear fenders. What offset do you need to run to make them flush? My fenders are rolled. I'm just trying to get an idea of what size wheel adapter to run.
Old 09-27-2010, 06:57 PM
jester1614's Avatar
a 1 inch spacer/adapter is what i used on my y2k rims to make them flush
Old 09-27-2010, 06:59 PM
bigj2717's Avatar
My ZR1's were 17x11 with 50mm offset and they set flush
Old 09-29-2010, 10:00 PM
R1ch's Avatar
They are probably inset about that far so that should work. Do you have pics of yours?
Old 09-29-2010, 10:05 PM
9WhiteCamaro9's Avatar
i thought about having my DD C5's widened to 11's in the rear and get a spacer/adapter to have them sit out a lil in the rear and may try the same for the fronts but leave em the same width and id like to see pics of the Y2K's also to get an idea
Old 09-29-2010, 11:54 PM
Xsta Z 28's Avatar
Run a 20 mm spacer, which will net you a new offset of 38 mm . . . which on a 10.5" wide wheel out back is perfect!
Old 09-30-2010, 01:48 AM
^ what about a 9.5in wide wheel
Old 09-30-2010, 09:16 AM
Xsta Z 28's Avatar
Question
C5 thin spoke? . . . "should" have an OEM 63 mm offset, you can run up to a 25 mm or 1" spacer/adapter and still fit.
Old 09-30-2010, 09:44 AM
R1ch's Avatar
Thanks for the info man.
Quick Reply: What offset to be flush on Camaro?
