Question about 19'' on a 00 Z28
Old 10-15-2010, 09:20 AM
Bones280's Avatar
Default Question about 19'' on a 00 Z28
Will 19's fit on a 00 z28 or do I have to make them fit?
Old 10-15-2010, 09:29 AM
sandsk8erz400's Avatar
Depends on the offset, width of the rims, and what series tire you go with. It's definitely been done, and with the correct aforementioned info , they should be good to go. There's lots of threads on here about people with 19's, some had to do work, others just bolted them on. A search will turn up tons of results.
-Brandon.
Old 10-15-2010, 09:35 AM
Bones280's Avatar
I don't have tires yet but the wheels ar 19x11. Thanks I'll see what I can come up with.
Old 10-15-2010, 09:39 AM
cemlsx's Avatar
you can see the offsets that will fit your car here :
https://ls1tech.com/forums/wheels-ti...must-read.html
you might need to run spacers for some offsets and do the BFH mod if you put too wide tires , but other than that , you shouldnt have any problems
Old 10-19-2010, 08:06 AM
katz_2003's Avatar
+1 for cemlsx
