Strano springs + Drag Radials
I did the Strano/koni setup a while back and am running 19" ruff racing 278. I wanna buy some 16 or 17" wheels with drag radials but dont know what size will fit with the lowered car. Anyone running this setup with DR and if so what size. I know all that matters is the height but i want it to look tucked under with out having to roll the fenders. Thanks
Thanks guys
so 315 Nitto NT05R's i need to roll fender and cut bumpstops? cruddy
The mt 315s fit with a 17"? very good to know. I wanna go with the weld rts 15 in back and 17 in front.
What height is the tires abeasst? 315/?/17?
I ran 275/50-15s ( 26" tire) on 15x8.5 Centerline Warriors on the rear at the track for quite a while. They fit and don't rub at all although they stick a little past the fender. In terms of the Stranos being too low for that size tire they are not. I now have 275/60-15s (28" tire) on 15x10 Weld RTS rims. During regular driving the are fine and have plenty of clearance all around. I think they are rubbing somewhere under WOT but I haven't had time to take a look. I'm sure a 275/50-15 on RTS would clear no problem.
Larry
As mentioned every car will be different so you have to check. Here are shitty pics of both setups but you can sort of compare the fender clearance . Centerlines first, Weld RTS second.
Larry
