Who's running 335s?
Old 09-14-2011, 01:39 PM
salemetro's Avatar
Default Who's running 335s?
The sticky is a little vague on this...it states;
"11.0" ... +45 to +56 mm .... 305, 315, 335"
So, what is the offset for an 11" rim with a 335 on it, using a stock rear end on a 4th gen (specifically, 1996) f-body? I'm going to have some 18" wheels built, and would like to figure out the correct offset. The rear on my car is narrowed, but if I have the correct figures for a stock rear, I can adjust from there.
Thanks in advance for any help
Old 09-14-2011, 09:02 PM
69TA's Avatar
you will need a 11.5" wheel and
run like an 8" backspace
roll the fender lips
bfh mod the $hit out of the inner wheelwells.
adj panhard bar
If you need help:
I rent the roller tools for $40
Have a new pair of Fikse 11.5's for sale
Old 09-14-2011, 09:04 PM
WS.666's Avatar
I have 335s on my 17x13 ZR1s. I wouldn't feel comfortable putting them on an 11" or 11.5" wide wheel.
Old 09-14-2011, 09:32 PM
meine96ws6's Avatar
my buddy hammer the wheel wells, try using some arp longer studs and a spacer..
Old 09-14-2011, 09:42 PM
VinR1's Avatar
Ive got some pretty wide BFG KDs 315\35s on 36mm offset 17x11 ZR1s. Car is lowered 2" with an adjustable PHB and rolled fenders. Oddly, I have no rubbing whatsoever on the inner fenders and just a very slight rub on the driver side outer quarter if taking a right hand curve really fast. Im still on stock swaybars fwiw
I do have a pair of 335 Hoosiers in my garage but will probably be a month or so before I attempt them
Old 09-14-2011, 09:48 PM
VinR1's Avatar
...should also mention the KDs were dead on 13" wide when off the wheel, sitting on its side
Old 09-14-2011, 10:14 PM
salemetro's Avatar
adj panhard bar
If you need help:
Yeah, I'm buying the Eastman roller setup....figured it's a good thing to have. As far as the wheels, I just sent the $$$ to True Forged. They are going to do up a set of 3-piece wheels for me, once I figure out all the dimensions. They are currently giving a nice discount to LS1Tech members to "advertise" their products....so I kinda jumped the gun, and sent the $$$.....so I didn't miss out on the killer deal.
Interesting though, that after searching on here, I've found a few people that have been able to run 335s on 17x11 wheels. I can't imagine 17x18 being any different. Is the general consensus that 11.0 is too narrow?
I've also considered using my plasma cutter to perform a little strategic "surgery" on the fender wells, if needed.
Old 09-14-2011, 10:24 PM
salemetro's Avatar
Body hammer, no problem. Wheel spacers, hell no. I'm having the wheels custom-built, so I'm going to do my best to make sure that everything fits as it should.
Old 09-14-2011, 10:29 PM
BADBOYZ28's Avatar
I ran 335's on a 17x11 TT2 on a stock length rear end and now I'm running 345's on
17x11 TT2 on a narrowed 9".
Old 09-14-2011, 10:36 PM
SHovV's Avatar
im running 335's on 18x12's. but i minitubbed my car. my back spacing is 8 3/4 for the 12" rim on a stock length 10bolt. so i would guess BS for a 11.5" would be 8 1/4.
Old 09-14-2011, 11:05 PM
salemetro's Avatar
Yeah, I saw your build...looks killer, and like a lot of work! Thanks for letting me know what your backspacing is...that definitely helps.
Looks like most manufacturers that I can find list an 11.5 as a minimum...I guess that settles the wheel width question.
Old 09-14-2011, 11:06 PM
white man's Avatar
guys with the 17x13, will a mini tub be all thats needed to fit a 335 or 345? Going to be getting a new set wheels in the next year and want to get what needs to be cut up out of the way.
Old 09-14-2011, 11:07 PM
Mr.z/28's Avatar
Ive seen 335s mounted on 17x11 inch wheel.
Old 09-15-2011, 12:49 PM
salemetro's Avatar
I just found a cool tool called a Percy's Wheelrite. Looks like I'll be able to measure everything accurately and easily once the new rear goes in! No more guessing....
Old 09-15-2011, 08:12 PM
carlos64030's Avatar
Just so you know in case you don't, someone here on this forum rents that tool.
https://ls1tech.com/forums/wheels-ti...ools-rent.html
Old 09-15-2011, 10:32 PM
salemetro's Avatar
It only cost me $175.00 to own....but thanks for the info. I'm kinda weird about tools, I'd rather buy what I need...not to mention, I have friends that might need to modify some fender wells soon as well.
