Need help drag wheels
The car is a 94 lt1 with factory brake setup on the front a 00 camaro ss rearend with factory ls1 brakes. with factory ride height not lowered.
every link i go on its a different story or someones opinion is different...
i been looking everywhere for a hour.
i dont wan2 spend alot on a drag set up i kno the summit and jegs wheels are heavy thts really not a problem with me with the weight..
i would like to go with the fifteens.
but wan2 run a 275/50 or 275/60 tire which is better?
the next thing is some ppl say u need to grind calipers which i understand.
but on the other hand with the studs and spacers is tht true.??
What size wheels do i go with?? and need to kno the backspacing for the rear and front of using the summit or jegs set up..
u call summit or jegs there clueless on there info
thanks. hope i can get some help.
I ran the summitt stars on my car a couple years ago.. This is the size rims, tires and Backspace I used:
Fronts were 15X4, BS 1.75 with 26x6x15 MT Sportsman SR's, rears were 15X8, BS 5.5 with MT ET street radials 275/50/15.
I had to grind all calipers to get these to fit, I did not use any spacers....
Just go with the Summit brand like I did John. They are a nice budget wheel that looks good.
Pretty much the setup I run now, but I use 165/80/15s for front runners.
thanks
i looked at ur pics are those the summit wheels in tht pic coming off the line
I have a set of prostars for sale. They are lighter than the jegs and summit wheels but as others have mentioned do require grinding. Most people run a 5/16 spacer upfront and grind down the rear calipers until those wheels fit. Others run a spacer on both the front and back with minimal grinding but swap out the rear wheel studs for peace of mind.
As far as tires go, its all personal preference. I like the rear tires to be 275/60/15 as it fills up the fender well better.
Here are my prostars for sale, if you are interested in picking up a set. There are many options out there but as far as budget/ weight goes these are ranked pretty high.
https://ls1tech.com/forums/parts-cla...-prostars.html
