Best tool 4 grinding Calipers??
Hey guys just seeing whats the best tool for grinding calipers is it an electric angle grinder or a air powered angle die grinder thanks
Awsome thanks man! I bought some centerlines with slicks recently and they almost fit but some grinding should do the trick theyre 15x8.5 with back spacing of 4.34" i think so it shouldnt be too much
A little advice: I would use fairly worn-down brake pads in the back, or if you have new ones then sand them down a bit with the grinder. I tried to put 15x8 Prostars on my car with new pads and I ground completely through the caliper, even though I was constantly stopping and checking for fitment. It was STILL rubbing where I ground through the caliper.
