275/40/18 on 18x9.5" ???
Picked up a set of z06 replicas for cheap, wondered if I can throw 275/40/18 instead of 35 series on?? I can save close to $300 with this tire size as opposed to 35 series, not to worried about 1-3mph inaccuracies on the speedo. I'm at stock height and the wheels are 18x9.5" with the 50mm offset.
I appreciate the input.
Thanks
Thanks
Anyone else have anymore input? Looking to pick up the tires soon before they go off sale. I have searched and nobody has given a direct yes or no. My suspension is stock and from what I have read going from the 35 series to the 40 series is only adding total 1".
I would appreciate the input.
thanks again
thanks again
youll be fine your talking about a 3/4 inch of height. ride will not be a noticable difference the ride really has to do with the tire you pick. and how picky you are everyone is different
Thanks again for all the input guys. Kuhmo ASX All seasons are up for sale for 600 shipped at that size, every other size (265/40, 265/35, or 275/35) a set of tires is up in the 800 range. And coincidentally I have had very good experiences with the ASX series from Kuhmo on my past vehicles.
This also makes me almost positive that the guy that I bought the wheels off of was lowered. The corners/shoulders of the tires had terrible signs of rubbing from what looked like either the fender or steering knuckle (and he was running 275/35/18 all around).
Thanks again
Thanks again
Does Nitto drag radial come in a 275/40/18 that's the size what's on my 94 Z28 now, i'm planning on going with the nitto 555r over the winter can't find this size nowhere..
My bad, thought you just wanted them on the rear.
IMO, 275/40/18 F & R should be no problem.. If by some chance the abs light does come on you can change the tire size with any hand held programmer, or take it to your local tuner and have him do it.
BTW, don't know if you've bought tires yet but you can get the Falcon FK 452's for $583.88 and the Nitto NT 555 Extreme Performance for $591.92 both shipped from DTD.
http://www.discounttiredirect.com/di...0&rd=18&cs=275
When doing a search for tire sizes, I always type it both ways: xxx/xx/xx AND xxx/xxRxx. You might have pulled up my thread if you typed in the latter.
https://ls1tech.com/forums/wheels-ti...ano-konis.html
