wheels rub?
Old 11-12-2012, 05:33 PM
across281's Avatar
Default wheels rub?
ok so before i purchase these wheels i would like to know if i will need spacers or anything on an 01 formula so i can get everything together they are 17x9.5, tires are 275-40-17 any input?
Old 11-12-2012, 06:47 PM
Donohue96M6Z28's Avatar
The wheels offset/backspacing is needed.
Old 11-12-2012, 10:37 PM
across281's Avatar
alright is there problems with all 4th gens?
Old 11-13-2012, 07:22 AM
TexasTarnation's Avatar
No we need the back spacing of your rim. Look at your order form, it should be like 40mm offset or something like that.
Old 11-13-2012, 05:07 PM
across281's Avatar
wheel offset says 54.0?
Old 11-13-2012, 11:25 PM
across281's Avatar
thankyou for the input did a bit more research these are the same size as the ones that came on a ws6 and the springs are also the same on formulas and ws6's 01+ so i should be fine
Quick Reply: wheels rub?
