Anyone have pictures of 255/50R16s mounted on stock wheels?
I'm looking at buying a pair of 255/50R16 drag radials for my stock wheels. Anyone have any pictures of a side view of their car where both front and rear wheels can be seen?
I have 245/50R16s on the front now, will the 255s change the stance of the rear any?
I don't want the stance to look goofy or odd with 2 different tires in the front and back. So I just wanted to see if anyone else is running a setup like this and has pictures of their tires on the car so I can get a general idea.
Thanks
Car will be driven on the weekends to and from the track with some passes while at the track.
Thanks
I can say i had 17" rims on the back with 315 i moved to 285 when i put my 18" on and to be honest i can not tell a difference on such a low number, now i can tell a difference between 275 and 315
16's would look goofy with 315 i would go with 275 or something meatier in back since they are 16's all around for a stance
I had 255/50/16 put on all 4 corners of my car. I couldn't tell any difference. The tire height of the 245 is about 25.6" and the 255 is 26". Less than .5" difference. I hope this helps.
I have a Diablosport Predator, so I just changed the overall diameter of the tire in the PCM to take care of the speedometer reading.
Here's a BFG street tire in 255/50/16
This is the best one I have of my M/T 255/50/16
I'm taking the car out in a little bit, I'll try to get a close up of the M/T. You can tell it looks bigger,I like the slight bulge.
