Wheel info needed.
Old 08-30-2013, 08:13 AM
buck6680's Avatar
Default Wheel info needed.
Buying a set of TT2's for a 02 ceta. Running goodyear eagle 275/40/zr18 F1 GS tires.
They are 9.5 in wheels & I can get one with 6.75 BS, 38mm offset, or another with 7.25 BS, 51mm offset. Can someone with more experience in this field advise which would be the best fit for normal driving conditions? I don't want to have to modify anything. Any help would be appreciated.
Thanks,
Old 08-30-2013, 11:29 PM
QuicksterZ's Avatar
I believe you should be fine
Bolt Pattern
5 x 4.75" or 5 x 120.65 mm
The numbers in the columns are as follows:
WIDTH ..... OFFSET ......... WIDTH OF TIRE
Front and Rear
7.0" ..... +35 to +40 mm .... 215, 225, 235
7.5" ..... +35 to +45 mm .... 215, 225, 235
8.0" ..... +38 to +55 mm .... 225, 235, 245
8.5" ..... +38 to +45 mm .... 235, 245, 255
9.0" ..... +38 to +56 mm .... 255, 265, 275
9.5" ..... +38 to +56 mm .... 255, 265, 275, 285
10.0" ... +38 to +48 mm .... 265, 275, 285
REAR Only
10.0" ... +38 to +54 mm .... 275, 285, 295
10.5" ... +38 to +50 mm .... 285, 295, 305, 315
11.0" ... +45 to +56 mm .... 305, 315, 335
NOTE: 315 series tires DO NOT fit 9" or 9.5" wheels. It will not be discussed.
Old 08-31-2013, 03:55 PM
99Bluz28's Avatar
Either one will work fine, Go with the +51 offset if you want the wheels to have a tucked in look, +38 if more of a flush look is what you want.
Old 08-31-2013, 04:22 PM
buck6680's Avatar
Decided on the 38's. Thanks to you both for the replies.
Old 09-04-2013, 04:27 PM
LS1Tech Platinum Sponsor
rudytirerack's Avatar
Good choice.
Quick Reply: Wheel info needed.
