Needing some new tires for my 18"s
Old 10-02-2013, 08:00 AM
kylemm1002's Avatar
Default Needing some new tires for my 18"s
So my car came with dale Earnhardt jr killer wheels. After researching it looks like they are 18"x8.5" all the way around.
Currently has a 275/35/18 all the way around. I'd prefer to have a wider tire out back. And I know the 275 is pushing it on a 8.5" wide rim.
Thoughts are to go with 245/40/18 up front and a 275/40/18 out back. Will the that mess with my abs? Seems like about 3/4" difference, I tried searching but got mixes results. Wanting a DR out back with some cheap summer only tire up front. Car is barley driven.
Or if there is a different size you guys think would look/work better let me know!
Car is lowered on bmr springs and slp bilstein shocks with umi everything else!!
Thanks!
Old 10-03-2013, 07:45 PM
kylemm1002's Avatar
Does anyone have any 275/40/18 pics they can post? Seems like it will fill the fender well up a little more then the 35 series. I also don't like if I do a 245/40/18 up front then a 275/35/18 will be shorter...I don't think that would look very good.
Old 10-04-2013, 08:32 AM
Wallj's Avatar
I just recently replaced tires on my c5 wheels. I have 245/50/17 on front and 275/40/18 on the rears. The rears fill up the fender well very well. It's actually so good (at least to me) that I plan on only lowering the front to get rid of the fender gap there and just leaving the back stock. I can try to get pics later after school and post them up for you if you'd like.
Old 10-04-2013, 01:37 PM
kylemm1002's Avatar
Ya that would be great! Seems like 275/35 is the most popular size so having a hard time finding good pics with the 40series
Old 10-04-2013, 02:59 PM
99Bluz28's Avatar
If you don't want it to mess with the ABS then go with a 245/45/18 in front and a 275/40/18 rear
Old 10-09-2013, 07:38 PM
kylemm1002's Avatar
Bump for some pics and more opnions!
Old 10-13-2013, 08:29 AM
kylemm1002's Avatar
What about using a 235/40/18 and 275/35/18? Seems like they are very close to factory over all height. And it seems the 35series is more popular then the 40 for the rear.
Bump for pics.
Old 10-13-2013, 04:35 PM
99Bluz28's Avatar
yeah, you'll still probably be fine with a 235/40/18 front, and a 275/35/18 rear even though a 9" wide wheel is the recommended minimum width for a 275/35/18.
I'd recommend going with a 255/40/18(26") in the rear and 235/40/18(25.4") up front if all your wheels are 8.5" wide. FYI, you'll get better overall performance from your tires when mounted on wheels within the tire manufacture recommended size range.
Old 10-18-2013, 09:41 PM
kylemm1002's Avatar
Well for now I got some 235/40/18 for the frot and still have my old 275/35/18 out back for now. I'm going to get a set of nitro nt05 in a 275 before next summer I think. Just a few picks for reference.
Quick Reply: Needing some new tires for my 18"s
