1996 Z28 max tire size
Old 05-22-2014, 06:00 PM
xxx-zodiac's Avatar
Default 1996 Z28 max tire size
I have a 1996 Z28
what is the max tire size that can fit and not rub..
1) max on stock rims.
2) max with new rims. (what size and offset do I look for)
can stock 1996 corvette rims from fit the 1996 Camaro?
Old 05-24-2014, 07:24 AM
leadfoot4's Avatar
A couple questions first.....Is your car at stock ride height or lowered? In order to fit the max width tires without rubbing, the rear axle has to be centered under the car as closely as possible, at ride height. Are you prepared to buy an adjustable panhard bar, if you don't already have one? What kind of "max width" tires are you looking for, drag tires or street/road course?
Old 05-24-2014, 07:33 PM
xxx-zodiac's Avatar
Stock Height.
Not now. unless I have to. for 1 or 2 cm in not.
Street.
Old 05-29-2014, 11:45 PM
xxx-zodiac's Avatar
Anyone know if OEM C6 Corvette wheels and tires would clear?
Old 06-04-2014, 04:36 AM
Jeremy 92 RS's Avatar
1) The max "safe" width tire for stock 16x8 wheels is 255. You could probably get away with a 275 in the rear if you're not pushing the car too hard , but the sidewalls of the tire will bulge and it looks goofy to some people. Not recommended.
2) This question is too vague. There are too many variations in size and possibilities to give 1 answer. What wheel were you thinking about?
3) Yes they will. Direct bolt on.
4) OEM C6 wheels will fit generally if you use a 1" wheel adapter/spacer in the rear.
Quick Reply: 1996 Z28 max tire size
