Cam/Nitrous 4.11's T-56 what size rear tire for 1/4 mile?
Just like the title says. I'm running M/T ET Streets right now. 26x10.5 on a 17" rim. Right after the 9" swap and the new addition of 4.11 gears I notice lots of excessive wheel spin. I can pedal out 1st and come out decent but I know I can get more out of my launch with a taller tire and more gas off the line. Anyone have a similar set up with success? What height rear tire did you use? Thanks
http://www.f-body.org/gears/
everyones set up is different use this to best figure out your set up. shot in the dark Id say 28" unless you have a redline high enough to get away with a shorter tire
