Leaking Wheel
Leaking Wheel
So my car has a leaking wheel. You read that right, wheel, not a tire. It's a slow leak from a small pinhole and will lose about 3-4 psi over 24 hours. I bought some silicone tape supposedly durable up to "700 psi" and I'm planning to stick a strip over the hole on the inside when I get some new tires mounted. I've also heard of using solder or epoxy, but the tape seems the easiest. Any opinions? Thanks!
