will 10.5 fit on a 69 nova
I run a 15x8 wheel on a 70 And 72 Nova. The back space is 5 3/8 and a 275/60/15 drag radial. It has 9.5in of tread on the ground and 11in in the section width and 28in tall. All suspension and wheel well are stock.
Running 29.5x10.5 et drags on the back of my 72 nova. Had to relocate the rear of the springs, used the comp engineering relocate kit. Where the shock mounted, i cut out that small section moved the shocks inside the rails and worked the wheel well in.
Running 29.5x10.5 et drags on the back of my 72 nova. Had to relocate the rear of the springs, used the comp engineering relocate kit. Where the shock mounted, i cut out that small section moved the shocks inside the rails and worked the wheel well in. Im running 15x9 wheels with a 4 1/2 bs.
