315/40/17 on a 17x9.5???
Old 01-19-2005, 07:47 PM
CATCH ME's Avatar
Default 315/40/17 on a 17x9.5???
will this tire fit?? looking to buy a set of zr1 wheels and was wondering if i was gonna run a 315, do i need a 17x11, or can i do 17x9.5 all around???
Old 01-19-2005, 08:10 PM
f-bodman's Avatar
It depends on your definition of "fit". To do it safely you'll need a 17x11.
Old 01-19-2005, 08:14 PM
Mike98WS6's Avatar
I would not recommend putting that tire on that size rim.
Old 01-19-2005, 08:20 PM
GM Muscle's Avatar
Since you havn't bought the wheels yet, get the 17x11s if you plan to run 315s in the rear.
Old 01-19-2005, 08:33 PM
Poik's Avatar
315s on a 9.5" wheel won't give you any more tread width than a 275 on a 9.5" because with the 315 it just bulges over.
Old 01-19-2005, 09:18 PM
CATCH ME's Avatar
thanks guys just lets me know to get the 17x11's
Old 01-23-2005, 04:20 AM
I SPEED's Avatar
If I were you, I would stop being such a ***** & put some HRE wheel's w/315 nitto's. If you did that you might be able to finally hook, & wouldn't always lose to all those little old ladies w/ ele. wheel chairs down there in St. Pete. Yea c'mon!
Good to see you on the forums again Matt. This must mean it's finally fixed! Just how much money did Kevin's **** up finally cost you. You should send him the bill. Damn 5.0 mechanics & their vast knowledge of absolutely nothing.
Old 01-23-2005, 01:35 PM
That's what she said...
TheBlurLS1's Avatar
looking at the mods in your sig, you'd better spring for the 17x11's and 315 drags, or else your going to do a sit-n-spin at every stoplight.
but no the 315's are NOT good to run on a 9.5 inch wheel. you are just asking for trouble, plus, like stated above, they will look like balloons. a 315 nitto drag radial is the narrowest 315 tire out there, if you HAD to put a 315 tire on a 9.5" wheel, this is the only one to do. a 315 nitto is about 1.5" narrower than a normal 315 tire (gs-d3 etc)
i'm going to run the 315 nittos on my 17x11 TTII's
Quick Reply: 315/40/17 on a 17x9.5???
