widest tire on 9.5" rim
im plannin on gettin black z06's 9.5's and i wanted the back tires to be wider i was thinkin on a 315 would they fit on the rim 9.5's 17's
Here we go again. This has been a big debated issue on here and on Camaroz28.com and a lot of guys say that it is unsafe and others say that it is fine. I have them on my car and I think that they are fine. Of course, my car is a garage baby and I put them on for looks only. If I was road racing, I wouldn't be running a 315 on a 9.5 inch rim. Below are some pictures of mine. Do a search and you will se all kinds of arguments.
https://ls1tech.com/forums/attachmen...chmentid=22630
https://ls1tech.com/forums/attachmen...chmentid=23314
for a 9.5" rim i'd say you could do it and it would work but like above i wouldn't road race on them...but the stock rim size for our cars are 9" that is where you run into most of the problems...those actually don't look that bad...and i'm definatly not a fan of the 315's on a small rim...
That's what she said...
the 315 nitto drag is pretty much the only one you can think about doing, considering it is not as wide as any other 315 out there. it will still look silly and not be safe. just stick to a 275 series untill you get some wide wheels. you can probably get those z06's in a 10.5" width and put a 315 on no problem.
Posted by: TheBlurLS1
https://ls1tech.com/forums/attachmen...achmentid=23314
And it is safe, like I have said before, nobody can give a single incident where there has been a tire failure from putting a 315 tire on a 9.5 inch rim.
Originally Posted by n2oblkz
I don't think that this looks silly!
That said, he still runs 315s on 9.5 inch rims
Just be extra careful on your tire pressure.
