Definitive weight of OEM Z06 polished wheels
Old 03-10-2005, 03:22 PM
Goodrich's Avatar
Default Definitive weight of OEM Z06 polished wheels
Just weighed my new OEM Z06 wheels and I know there was a lot of questions posted on here about this topic so I thought I'd share what I found out.
The rears are 20lbs each and the fronts are 17lbs each. I weighed them on a sliding weight scale (the kind you see at the gym) so Im pretty sure this is an accurate measurement.
Old 03-10-2005, 03:37 PM
UMD_Jesse's Avatar
Location: Fairfax County, VA (You know you're here when you see the bad roads)
who makes the wheels? are they original GM, AFS, etc.? Also, where did you get them, they used to be all over ebay for cheap, but cant find good prices anymore.
Old 03-10-2005, 03:40 PM
Goodrich's Avatar
They are the OEM corvette Z06 wheels (GM). I got them new on ebay.
Old 03-11-2005, 02:30 AM
1999 SS's Avatar
the oem zo6 wheel will not weigh the same as the aftermarket wheels because the factory zo6 wheel is made from spun aluminum i beleive and aftermarkets are cast.
Old 03-11-2005, 04:51 AM
ZR2877's Avatar
Thanks for that info. That is lighter than I thought they would be.
