View Poll Results: Which is the best DOT Tire on the market.
Nitto 17"
16
13.68%
Mickey Thompson ET Drag Radial 17"
86
73.50%
Forget DOT and Go with 16" Slick (please post Brand)
14
11.97%
Other Brand of 17" DOT (please Post)
1
0.85%
Voters: 117. You may not vote on this poll
Best Drag racing tires.
Old 05-15-2005, 01:22 PM
Texas_WS6's Avatar
Default Best Drag racing tires.
Ok, I am sure this has been asked before, but I would like some fresh opinions since something new might be out there. Please check the pole and if there is something else you like better then check other and then please post what the other is. Please keep in mind I would like to have tires that are DOT aproved, but if all the DOT aproved tires are junk and a waist of time, let me know that too. Thanks.
Maybe I should also state I want something that will work in the low 11's.
Old 05-15-2005, 01:26 PM
12stones's Avatar
Mickey Thompson ET Street Radials are awesome! you wont have ANY problems hooking up with those tires! they dont have very long treadlife, but for a soft tire what else would you expect?
Old 05-15-2005, 01:46 PM
Texas_WS6's Avatar
MT makes ET Street and ET street radials, which one?
Old 05-15-2005, 04:27 PM
02 Camaro SS's Avatar
the MT's seem the best way to go if you don't mind the short tread life
Old 05-15-2005, 08:28 PM
SSmokin 01's Avatar
I've run 315 nitto Dr's, ET Streets, and 275 MT ET street DR's. All in 17". The MT ET Street DR's are by far the best out of the 3. Nitto's were the worst of the 3 but will probably last at least 6k miles more than the other 2 on the street.
Old 05-16-2005, 04:35 PM
LS69TA's Avatar
I heard the Nitto's last longer on the street. I hope so anyway. Just ordered my 2 275/50/15's from Discount Tire, and my 15x10 Prostars from Summit about an hour ago.
Old 05-17-2005, 11:51 AM
7 Second Club
ty_ty13's Avatar
you'd better get some bogart wheels and some massive tires to hook a H/C and nitrous car.... my MT Dr's wont even hook my 4.10 yank SS4000e cam only setup...i ordered my bogarts yesterday... i plan to go heads and spray later also....
15'' rim with a 9.75'' width...
10.5 slick
Old 05-17-2005, 08:51 PM
dave70's Avatar
with all that power you should be thinking of a new rearend lol! lucky it lasted this long. if you start hooking it may be the end of it
Old 05-18-2005, 11:02 AM
Assassin's Avatar
I use 16" bfg dr's on my C4.... here'z some pics of the punnishment I give them.. https://ls1tech.com/forums/wheels-tires/321140-bfg-dr-s-8psi.html
btw, I think the bfg dr record is in the low 8's.....
Old 05-18-2005, 08:28 PM
Texas_WS6's Avatar
The rear end is the next step on my mode list, after I finish the 408 (or if it gives up before then)
I think my sign is a little miss leading. I am not running the 408 at this time. I am still on the stock 346. I do not have the AFR Heads yet. They are for the 408. I did change cams two weekends ago. I just cam back from Texas Speed (whom I got my cam kit from) and had the car tuned and Dynoed. I do now have those results. So whith thats results I hope I can make a good geuss as to which tires to run (with ya'lls input). The car was pulling 302 RWHP (threw the big converter) at 5400 RPM. I now makes 371 RWHP at 6800 rpm. Almost 70 HP from a cam, not bad! On the Juice it use to make 450 peak RWHP at 4400 RPM (150 shot running 12.5 A/F). It now Starts at 450 RWHP at 4400 rpm, and climbs to 472 RWHP at 6800 rpm. Thats with it tunned to 11.5 A/F. This cam loves the juice.
So I am looking for tires that will hook this power on my 17" wheels, so I can quicken the 10 bolt death!
Old 05-19-2005, 12:13 AM
dnkynrbk's Avatar
Go with the ET streets I lowerd the air pressure to 20 psi and didnt spin at all off the line and I dont have a stall and still pulled a 1.7 in the 60feet I have the 17 inch
Old 05-19-2005, 12:14 AM
dnkynrbk's Avatar
the radials sorry et street
Old 05-19-2005, 06:37 AM
Wicked_Hugger99's Avatar
put 16s to choose MT DRs but was thinkin 15s for some reason( i just woke up)
what about the MT DRs for the 15in rims?
didnt see that as an option so i shouldve put 17in MT DRs Mine seem to dead hook on the street but havent had any 1320ft passes on em yet.
Old 06-14-2005, 06:07 PM
BBQLS1's Avatar
Mickey T's
Old 06-14-2005, 06:41 PM
Brett95z's Avatar
I will never understand why people buy different rims to put drag radials on? Is it because you are scared of breaking the rear? It makes no sense when you could have a et streets when your not going to be driving the car on the street with them.
My vote is for The Et streets.
Old 06-14-2005, 08:43 PM
skippytheloon's Avatar
anything wrinkle wall will hook off the line, radials are iffy. I'd go with 26" or 27" tall MT ET streets for the best traction and still be able to drive in town.
My car rides on 27" MT ET streets for cruising and then I have my street tires on my ugly spare rims in my garage, I'm happier that way.
Old 07-06-2005, 09:32 AM
FungusMungus05's Avatar
How long are your ET Streets normally lasting?
Old 07-06-2005, 10:25 AM
GM Muscle's Avatar
The E/T Radial should do the trick no problem, I've cut mid 1.50s at street night with no real track prep. I would only plan on getting a few thousand miles out of them on the street. Mine just hit the wear bars after 1000 miles and about 15 passes. I spin the tires at about 110mph for 5 seconds in the burnout box though.
Old 07-30-2005, 04:01 PM
BMW ///M Nerd
BAD ASS TA WS6's Avatar
ET Drag Radials.
They hook up mint on or off the track.
Old 08-03-2005, 09:37 PM
Grave's Avatar
I'm looking into the 255/50R16 for my stock 16" wheels just sitting in my garage. Is this a wise chioce? So far, this forum and my local friends say the MT ET DR's seem the way to go. I was looking at the MT's or the Nitto's.
I'd only use my DRs on the strip, and most likely will swap from street to DRs once I'm already at the track. So tread life and street use don't apply to me.
Quick Reply: Best Drag racing tires.
