Advise: Help just purchased Boyd Coddington's smoothie 2 wheels and need advise
Hey all:
I just purchased some Boydd Coddington's smoothie 2 wheels for my 02 Z-28 and had a few questions.
1st my 02 Z-28 is lowered with the Eibach pro-kit which is 1.2
I went with 17X10'S all the way around and want to make sure I wont have any problems with the 10'S on the front. I will be running Fuzion 275/40/17 on the fronts. I think the offset is 38. I have been trying to find all the info on these wheels and see a few people on here have them but went with the 17X8'S on the front. Will the rub or hit on hard turns? I was told by the vendor I wont have any problems but I still wanted to hear from everyone on here first.
Also on the rear I went with the nitto drag radial 315/35/17 tires and wanted to see if I will have any problems with rubbing also on the back?
Please if you have these wheels share with me any problems or if I went the wrong way.
The rims will be shipping out on Monday
Thanks
I can call on Monday and see if I can get the 17X10'S changed to a 17X8 but wanted to find out first if I will have any problems.
Thanks
I have Boyd 18x10's on all for corners w/ 285 wide tires and only some very minor rubbing in the front on the plastic fender liner. Only happens at full steering lock though. 315's are really pushing it on a 10" wide wheel and w/ that offset you will have some rubbing issues, but you may be able to fix that w/ a BFH mod.
Also on the 315/35/17 nitto tires. They do run smaller then most 315'S plus on there website they state on there that the required rim for there 315/35/17 drag tire is 10-12" with 11 being the best fit. I had 9 1/2 wheels and decided to be a little safer and went with the 10" wheels.
With the 17X10 and a 275/40/17 in front I may not rub at all then.
Im sittin on BC Smoothies 17x10 with 285/45/17's all around here are some shots a have minimal rubbing up front and none anywhere else I have Bilstien revalves with Eibach Prokit and a few other suspension..I do also plan on 315's in ther rear in the future when new tires are needed..here are some shots for you..hope this helps..
Side shot
Front New Ride Height
Emblems Removed
Drivers Rear New ride Height
Side shot
Emblems Removed
Sorry I didn't get back to this sooner, luckily Shawn posted up some good pics for ya. Here's a few of mine anyway:
http://www.csramotorsports.com/phpB...php?pic_id=2220
http://www.csramotorsports.com/phpB...php?pic_id=2219
http://www.csramotorsports.com/phpB...php?pic_id=2216
http://www.csramotorsports.com/phpB...php?pic_id=2218
http://www.csramotorsports.com/phpB...php?pic_id=2214
The 315's will fit, they'll have a slight bulge but nothing drastic and you'll need to hammer the inner fenders a little.
You should be fine with the 315 Nittos.....Contact Todd at Pro Dyno to get the proper offset for the fronts, which I believe is 41p so that they will not rub......the front and rears need different offsets to fit correct..
John
John
