Do 20 X 10.5 zo6 wheels fit 02' SS?
Does anyone know if a 20 X 10.5 zo6 wheel fit on a the rear of a 02 SS Camaro? If so, what tire size should I use? Should I choose Falken or Nitto? Thank you!
here is a pic of a guy on camaroz28.com that is running 20x10.5 on all 4 corners.
http://technologyorgasm.com/upload/newwheels1.jpg
you might need to clearance the inner fenderwells in the rear depending on how much you are lowered. They will fit fine because they are a +56mm offset which is exactly the same as the 18x10.5
You will need to run a 285/30zr20........just get the cheapest one becasue you will not get traction anyways so it doesnt matter. Get your 20's for the street and some big and little's for the track and you're good to go
