Largest rear tire w/o BFH mod on 19" rims
Old 11-22-2006, 03:05 PM
big reg's Avatar
Default Largest rear tire w/o BFH mod on 19" rims
Guys, what is the widest rear tire I could place on a 19x9.5 wheel w/o using the BFH mod to make it fit. I am currently running a 275/30 on all four corners but would like to step up to a 295/30 in the rear. Will I have fitment issues. I have decent amount of space right now btw the rear tire and inner fender. I need to go bigger as in the spring I am installing a D1SC with a forged 347. Any help??
Old 11-25-2006, 06:32 AM
ws6on19s's Avatar
i run 19x9 19x10.5 Iforged Aeros 275/30 and 295/30 conti sport2 out back with eibach prokit
and i did have some issues with rubbing on the lip of quarter panel
eroc
Old 11-25-2006, 08:03 AM
LS1Tech Co-Founder
Nine Ball's Avatar
295s will rub on the lip if the car is lowered a lot. Shouldn't have to BFH the inner fenders with a 295 though.
Sounds like you may need to step down to an 18" wheel combo to get a nice drag radial
Old 11-25-2006, 09:27 AM
Kleeborp the Moderator™
MeentSS02's Avatar
It all depends on the wheel offset...if you have wheels that tuck really far in (CCWs do that in the rear), you'll be clearancing the inner fenders. I did with my 18x11 rims in the back, and I only run a 295 tire back there.
Old 11-25-2006, 04:43 PM
ws6on19s's Avatar
i seemed to have more issues with rubbing with the 12 bolt..after the adj ph
its alot better...I may roll the quarters and run 315/25/19 contisportcontact2 vmax
EroC
Old 11-26-2006, 09:12 AM
big reg's Avatar
Yeah, I was actually contemplating doing this so I can run a 295 drag radial out back. The car is lowered about 1.5", it has the Bilstein Ultra Performance suspension package. I could use a little better ride quality as well to be honest.
