18x8.5 35mm Another will it fit
Old 12-19-2006, 04:23 PM
dpw41285's Avatar
Default 18x8.5 35mm Another will it fit
Front and 9.5 rear, will they stick out to much in the front? i have learend from SEARCHING and reading the stickies a 9.5 will be close to sticking out to far i know its with in 3mm of offset tolerances. let me know what you think prolly run a 245 up front and 305 rear
Old 12-19-2006, 04:57 PM
Kev98Ta's Avatar
LS1Tech 20 Year Member
Trans Am's have slightly larger fender wells than Camaro's, you should be fine.
On a side note a 305 on a 9.5" rim is CRAZY man!! 285 tops.
Old 12-19-2006, 05:02 PM
michaelg589's Avatar
youre definatley not gettin a 305 to fit on a 18x9.5. sorry guy. like wutshisname said, 285 tops
Old 12-19-2006, 05:08 PM
dpw41285's Avatar
i meant 295, id be okay with w 285
Old 12-19-2006, 09:26 PM
Xsta Z 28's Avatar
Those offsets for a TA should be fine. I have 38 mm all aound on my Cmaro, and since the wheel wells of the TA are a tad wider, you should be golden.
A 245/40ZR18 front and a 275/35ZR 18 or 285/35ZR18 rear would be perfect.
Old 12-19-2006, 10:55 PM
dpw41285's Avatar
lowered with a pro kit if the rears sit flush i may be fucked unless its 26in dia
Old 12-20-2006, 08:41 AM
Xsta Z 28's Avatar
I do not recommend a Pro-Kit, especially on a Convertible. Too low in the back. Hotchkis 1" drop would be perfect.
If I can get away with a 10.5" wide wheel, with a 38 mm offset, and 295 series tires on my Converitilbe SS, I don't see how a 9.5" wide, 35 mm offset with a 275/35ZR18 would be a problem, especially on a TA. But you may have to roll the quarter lip. I did.
Old 12-20-2006, 01:26 PM
thunderdan74's Avatar
I have 18 X 8.5 front and 18 X 9.5 Rear both on -35mm offset. 245/40s in front and 295/35 in rear. Stock ride height Camaro. I had to roll the rear fenders.
They fit perfect. Tires tuck into the fenders by less that a 1/4 inch.
DO it!
Old 12-23-2006, 01:26 AM
dpw41285's Avatar
good thing i picked up my airlift kit for the rear
Old 01-11-2007, 11:27 PM
dpw41285's Avatar
thunder dan i bought the wheels you have hince the pm i sent you. i also put my stock rear springs in
