Cragar Drag Star FYI
I just bought a set of Cragar's version of the Prostar the Drag Star. I also have a full set of Prostars. Side by side they are identical. Only aparent detail is the Dragstars have 5 small allen headed bolts between every lug hole. Fit wise, they actually fit better than the Prostars. I was able to make them fit on the rear with NO grinding using a small (maybe 1/4") spacer. Where as the Prostars with the same spacer needed much grinding to fit. I am speaking of 15X8 with 5.5" BS. Also, the Weld center caps fit in the Cragars as do the lugs. Just thought I would share my findings.
I have Summit Stars and they too look almost indentical but if you look very close my spokes is a little bit wider the Prostars. But considering the price difference I'm not complinaing only thing is I had alot of grinding to do.
