jegs sport star wheels for my 98 ta will they fit without grinding.
Old 04-14-2007, 10:07 PM
95transamlt1's Avatar
Default jegs sport star wheels for my 98 ta will they fit without grinding.
I am thinking of buyin a set of these for my 98 ta are they good quality and will they bolt right up to my 98 trans am. they are like pro star knock offs . here is a link what do you guys think . http://www.jegs.com/webapp/wcs/store...61789_-1_97304
Old 04-14-2007, 10:21 PM
Photochop's Avatar
They're around 6 lbs heavier per wheel than a prostar, they fit without grinding on my 98 z28 with stock brakes/worn pads (can't comment on a thicker pad like hawks, etc), and use stock/stock style lug nuts. The weight is the only downfall to the rims, visually (besides the centercap not saying weld racing) they are pretty much identical.
Old 04-15-2007, 01:54 PM
Lythropus's Avatar
Originally Posted by 02EBZO6
...with stock brakes/worn pads (can't comment on a thicker pad like hawks, etc...
Old 04-15-2007, 04:21 PM
97lt1z28's Avatar
What sizes would you need to oredr to make thhem fit right? 4X15 up front and 10X15 out back w/ 5 inch backspacing?
Old 04-16-2007, 07:25 AM
Photochop's Avatar
Lythropus, the reason I mentioned stock pads is because on my old 99 z28 I attempted to fit some draglite xp's on the front I bought used from a forum member, but they didn't fit correctly at all due to baer eradispeed rotors and hawk pads being thicker than stock.
The 15x4 with 1.75" bs up front, and as of now they don't make a 15x10 with correct backspacing for our cars. Gotta run the real prostar out back, but they match pretty well.
Old 04-16-2007, 09:25 AM
SiL3NtXWS6's Avatar
+ 6lbs of rotating mass per wheel equals out to a decent amount...
Old 04-16-2007, 11:24 AM
Photochop's Avatar
Dude, you're killin me man! This is the 2nd thread on here that you've jumped on me for informing others on these rims. This is coming from a guy that thinks dual spiral flows off the header collectors is a 'relatively quiet' light weight street exhaust setup!
Not everyone on this site is trying to build a race car they drive on the street every so often. I don't know how much you drive your car and I'm not trying to start sh*t, but the majority of the population on this site do daily drive their cars or they are their nice weather drivers.
With everything factored in that I've mentioned, yes these do weigh more, but compare these to your run of the mill aftermarket chrome 18" zo6 wheel combo or something similar, you're still saving a substantial amount of moving mass by the weight AND the width of the wheel/tire. Yes the prostar is obviously the better choice weightwise, but you can't beat what these offer for the price if you're not building an all out track car.
Old 04-16-2007, 11:37 AM
LS69TA's Avatar
Old 04-16-2007, 11:48 AM
Dom
Dom's Avatar
These fit without grinding front and back?
Old 04-16-2007, 12:03 PM
formerly 2000blackcamaross (6-25-2013)
LSGUNSS's Avatar
I want to know about grinding also!!
Old 04-16-2007, 12:15 PM
Photochop's Avatar
Post #5
Fronts only
Old 04-16-2007, 12:16 PM
SiL3NtXWS6's Avatar
I'm not jumping on you for ****. Your car is your car, i don't care how you set it up. You want to go fast, don't cut corners. I gave my opinion, you gave yours. Cya.
Quick Reply: jegs sport star wheels for my 98 ta will they fit without grinding.
