10 inch prostars and 325/50/15 mt
What do you guys think?? To much tire for a 450 N/A car with a 300 shot in the near future.. I have bfg 275 but they dont hook at all. I am running a 3:42 gear on a 10 bolt.. and no other suspension mods.. Any help would be great..
thanks guys..
thanks guys..
you need 4:10s, at least 3:9s and the BS on the prostars is 6.5....... so good luck.
edit- they dont look as good but draglites have the right BS you need... 7.5... and you might want to at least consider some SFCs and LCAs for wheelhop but if you do hook your frame is eventually going to look like a twizzler.
werd up with all this comments so far!! that much N/A HP and 300 shot !!!! holy moses!! stock rear end too.. stuff aint going to last for long man, time to up grade before next time u press the button!!
I wouldn't even consider them yet. You need a fully adjustable suspension and a new rear end to run these.
Prostars and draglites come in a 7.5inch backspacing, which is what you want. 6.5 will stick the tire out too much.
Hope you're an auto car, otherwise you won't hook a "300 shot"...
The 300 shot is in the future. along with the gears and rearend real soon. and it is a m6 car. We will see how long that 10 bolt last.
Dont they make a 7.5 backspacing in a pro star rim?? i thought they do
