What size are my rims??
Old 05-31-2007, 10:07 PM
detroit_903's Avatar
Default What size are my rims??
I have a 69 camaro with centerline rims. The rear rims measure close to 11" wide. But they do not make 11" rims. They are mounted on 29.5x11.50x15 tires. Do you think the rims are 15x10?? Or do they make a 15x11 centerline rim? Only reason I want to know was because I wanted to order new rims and get the same size for a perfect fit
Old 06-01-2007, 11:52 AM
Xsta Z 28's Avatar
Most likely 10" wide. Rule of thumb is each rim bead is going to be about 1/2" each, and the measurement of a wheel occures between the two beads.
