CCW owners please come in!!!
Old 06-03-2007, 01:26 PM
Detoxx03's Avatar
Default CCW owners please come in!!!
I've had my ccw's for a month and everytime I clean them I still have water spots on them. I use Mother's aluminum polish. Am I using the wrong stuff or will this always be a problem?
Old 06-03-2007, 02:37 PM
Detoxx03's Avatar
sos anyone there?
Old 06-03-2007, 05:26 PM
AbsolutHank's Avatar
Hmm...maybe you aren't cleaning them often enough in between polishings? Dude, honestly...most of the aluminum polishes work the same, it just takes elbow grease.
I've had the best luck with the Adam's 2 step polish system www.adamspolishes.com
Old 06-03-2007, 05:52 PM
Detoxx03's Avatar
thanks.
Old 06-03-2007, 07:44 PM
GMMillwright's Avatar
Although I never tried it when I had my CCWs, I've heard that adding a small amount of vinegar to your water/soap solution will help eliminate the water spots. Here's a post with some good info:
http://ls1gto.com/forums/showthread....ight=clean+CCW
Old 06-03-2007, 11:18 PM
Sold The Fun Stuff :(
josh99ta's Avatar
You need more elbow grease to really polish out the water spots. A good compound with a little more cutting ability and some solid elbow grease and they'll come out.
Old 06-04-2007, 12:53 AM
Detoxx03's Avatar
Thanks. Who sells good elbow grease?
Old 06-04-2007, 01:08 AM
ultraz's Avatar
well, if it means anything, i had similar problems with my polished z06's. SOMEtimes the spots would come out with HEAVY METAL POLISH 3-step system starting with red, then green, then blue compound. THe other time IT DIDNT work, i had to use 2000 grit dry/wet sandpaper and wetsand the spots until they came out, THEN use the 3 step system to polish them back up.
Old 06-04-2007, 01:57 AM
LvDemKings's Avatar
Best that money can buy:
Elbow Grease
Old 06-04-2007, 11:15 AM
thmass6's Avatar
Elbow Grease
Ha, what the hell?! Can you seriously buy that stuff...it's probably just a jar of vaseline or something.
Old 06-04-2007, 11:27 AM
Shockwave179's Avatar
Elbow Grease
Rofl I knew something like that was coming.
