Proper torque specs for zr1's please?
well its one of those things where you just kinda gotta know how tight it too tight when using leverage...... obviously dont put a 3 foot bar on and have 2 people prying down or yeah you migth **** something up...... but if you have a torque wrench then try 100ft lbs like dude said
Will not warp the wheels but could certainly stretch the studs(which will weaken them) or warp the brake rotors. Lug nut torque has nothing to do with the wheels but depends only on the stud size(think of the stud just like you would any other bolt.) Tell us what stud size you are running and that will determine the torque. If they are stock studs on a late model f-body then they are 12mm, proper torque for a 12mm stud is 70-80 ft lbs. Because the stud is steel and the wheel is aluminum they expand at different rates when hot and will loose some torque, important to retorque aluminum wheels every 25-50 miles until they amintain the proper torque setting.
