Weld Prostars
Old 04-10-2008, 11:13 PM
2002ssls1's Avatar
Default Weld Prostars
I am looking at getting a set of weld prostars for my 2002 camaro SS. I am just a little confused if they will fit of not. The fronts are 15X3.5 and the rears are 15X10 with a 7.5 backspacing. What will I need to do to get these rims to fit. Any help would be appreciated.
Old 04-10-2008, 11:21 PM
jessedale98's Avatar
Just get a grinder and some primer paint. Each caliper will take approx. 45 minutes. After you grind them throw on a coat of primer so they dont rust. Then they will fit!
Old 04-10-2008, 11:26 PM
2002ssls1's Avatar
What part of the caliper will I be grinding? Will I also need longer wheel studs?
Old 04-10-2008, 11:28 PM
the part that is grinding. And no you will not need wheel studs.
now that I remember, heres what I did.
I got a -
grinder
paint
window chalk
I put the window chalk all over the calipers and put my rims on and gave them a couple turns, when it turns it will take the chalk off and show you where you need to start grinding!
Old 04-10-2008, 11:41 PM
2002ssls1's Avatar
Gotcha. Is this a problem to do this?
