Centerline Wheels with M/T 325/50R15 Drag Radials..Legend Series
Sold!!! Thanks! Bob
The rears are 15x10 with a custom 7.5 backspacing. These will fit with LT1 brakes. They have new Mickey Thompson 325/50R15 Drag Radials mounted and balanced on them. Tires are $194.95 a piece if you can find them, and the wheels are around $300.00 a piece new. We are asking $700.00 plus shipping for both rear wheels and tires!!!!!!!
The fronts are 16x7 with a 5 inch backspacing, they are not mounted with any tires. These should work on stock brakes and cost about $220.00 each. We will sell them both for $375.00 + shipping. Bob
Here are two pic's. Bob
None that I could find. Bob
Outdo your competition with the look and performance of the Legend Series wheels. These ORIGINAL Center Line designs are now available in a wide range of sizes & widths. This is a ROTARY FORGED billet aluminum wheel manufactured by welding the center section into an outer rim enabling you to CUSTOMIZE the backspace & width. Wheels are custom built for your vehicle at no additional charge -- the most common vehicles are listed below but these wheels also fit much more. Call us at 800-345-8671 x5 to discuss any questions including fitment advice. Wheels are brilliantly finished to a hi-polish mirror shine. 32-inch max tire size. 1625 lb load rating per wheel. Manufactured in the USA.
will they fit the ls1 brakes if they have been ground already to fit the prostars? will you seperate the tires and wheels? i would only be interested in the back wheels, thanks
also how heavy are they compared to say the prostars? thanks
