Destroked 6.0L F-Body Spins to 8000 rpm and Makes 811 whp
When you’ve got nearly 8000 rpm to play with, you can make a lot of boost and a ton of power from small cubes! That’s exactly what this destroked 6.0L with a 4.8 crank arriving at 332 cubic inches of high-rpm LS power does! The short-stroke motor makes 811 hp and 679 lb-ft at the tires on just 15 psi through a face-plated T56. Other motor details include LS3 heads and a PT8847 turbo.
Listen to this thing spin to nearly 8000 rpm! And who said only the over-head-cam motors can turn high rpm?
Discuss it here: https://ls1tech.com/forums/multimedia-exchange/1694240-destroked-6-0l-spins-8000-rpm-makes-811-whp.html#post17880819
