Made it in tonight!
reaction - .032
60ft - 1.50
1/8 - 6.88
mph - 99.59
1/4 - 10.98
mph - 117.45 (had to pedal it twice, 26inch slicks didn't quite make it though the 1/4 with 410s and spray)
DA - 1747 edit - rechecked Dragtimes
Off the footbrake
Jetted for 150 with a Nitro Dave Ls1 specific plate
http://www.youtube.com/watch?v=a98MqwUxjBo
Thanks to God and all those that helped me along the way! I think she has alot left in her, we will see as the cooler weather comes in!
Andy
reaction - .032
60ft - 1.50
1/8 - 6.88
mph - 99.59
1/4 - 10.98
Andy
Good work, now get a little more weight out while you're waiting on the cool air, and I think 10.50 is doable
EDIT: I just watched the video, the car spun, and you left off the footbrake.....
Put the 28 inch tire on, put the thing up on that transbrake, WOT, and let it eat. Coming out on the nitrous like that, and the hook from the 28 inch tire is going to make a BIG difference in the way the car runs, so much so that I think it's gonna go 10.50 in the heat, nevermind in cooler air.
What did the plugs look like after a full hit?
1. Leave on TB instead of Footbrake
2. Open the cut out (made 6rwhp and 6 rwt NA on dyno)
3. 28 tire and run it out the back door
4. Don't short shift it, like always when i make the first pass right
5. Bottle pressure wasn't quite a 1000, close but not quite
6. Work on the timing a little more, 2 members said add and one said subtract, I will work through this by reading more plugs.
Oh, about the plugs. I'm ashamed to say that I was so excited after the run and with the bad weather coming in quickly and me having to change tires to get home I didn't even pull them
Will do better next time tho
Just get the 28's on, do what needs to be done to make the room for them (28x10.5S et drag) and next time you go, open up the cutout and just leave off the transbrake, foot to the floor.
You'll see how that setup will work when you do that that's for sure, and then you can get a feel for the shock settings, if they're right. And pull the plugs, see what they look like after a full track pass.... that will tell the story.
10.6 is my guess just from putting on the 28 and leaving off the brake, probably around 122 to 125
I knew you couldn't stay away that long. Congrats on the 10's...nice!!
I hope to see you out there soon, I'm trying to get my new LCAs now so I can get the 28s on and let her rip
Thanks!
Of course it's still not going to be anything to challenge that silver bullet you drive.
