10 Second Club Now you are haulin! 10s are sweet
10.28 @ 134 1.53 60'.... Who says you can't get down on a 10 bolt...
Old 09-20-2009, 02:41 PM
ryarbrough's Avatar
Default 10.28 @ 134 1.53 60'.... Who says you can't get down on a 10 bolt...
Already posted in results, but I thought you guys would get a kick out of this...
Finally made a few good hits on the new nitrous kit last night (175ish hit on a ZEX perimeter plate). Previously the car had been 11.41 @ 122 on the motor. The best pass was:
60' 1.53
1/8 6.61
mph 107.48
1/4 10.28
mph 134.17
There is a brief mod overview in my sig. All of this on a stock cubic inch motor, factory stock 10 bolt, and factory torque arm.... Drove it to the track, ran a couple low 10sec passes (one of which netted a 136.5mph but a higher et), and drove it home. Needless to say, I'm really happy with the car!!!
Old 09-20-2009, 02:50 PM
wg871's Avatar
Good deal. I have a friend running a very similar setup as you
Old 09-20-2009, 06:54 PM
JFM-jr's Avatar
Yeah I had gone very low 1.4's on my 10 bolt but I put in the Moser before a 2 hour trip to the track could become a waste of my time.
Old 09-20-2009, 10:12 PM
LT1Formula007's Avatar
Wow, Thats very impressive.
Good Job!
Old 09-30-2009, 12:20 PM
CamaroRick's Avatar
damn i thought 1.7's were pushing it on a stock 10bolt,
Old 09-30-2009, 10:14 PM
silverz28camaro's Avatar
What gear? Its mainly the 6 speed cars with 4.10 that strip the pinion teeth off, then if that doesn't break the small 27 spline axle will. But in an auto the 10 bolt can last, what size tire? 26? the taller the tire the more stress there is. I'd say with a stick car 1.70 slipping the clutch is the limit but in an auto i've seen a local guy run mid 1.5xx all season long running 10.6-11.0
Old 10-01-2009, 01:51 PM
ryarbrough's Avatar
It's a 3.42 gear with a 28'' tire. One or the other is going to have to change because I'll be out of gear with much more nitrous.
Old 10-06-2009, 05:19 AM
BADBOYZ28's Avatar
Congrats nice to see other cars getting it done on a 10 bolt also. I did about the same high 1.3x 60ft's on a 10 bolt with 2 series carrier and 3.42's on a 26" Hoosier slick. Also with stock TA!! Only diffrence was I was trailered in cause I live bout 45 mins - 1hr away from track. BTW awesome MPH!!
Old 10-07-2009, 01:50 PM
navyblueSS's Avatar
Nice times.
Old 10-07-2009, 04:03 PM
01 ss vert's Avatar
Gives me hope!
Old 10-07-2009, 04:50 PM
jp74's Avatar
Great time. Awesome trap speed.
Old 10-07-2009, 05:37 PM
Rickys S/C Z28's Avatar
bad ***!!!!!
Old 10-08-2009, 07:10 PM
MattxFatal's Avatar
Damn dude...that thing rides the **** out.
Old 10-08-2009, 07:18 PM
lemons12's Avatar
What is up with the 60 foot??
I cut 1.50-1.53s consistently...
Old 10-11-2009, 06:02 PM
TORCHD 02 TA's Avatar
a 10 bolt in a A4 car is bullet proof compared to a 10 bolt in an M6 car..
Good runs though
Old 10-12-2009, 09:12 AM
ILLWIN's Avatar
I've run a 1.45 60ft. on the stock 10-bolt/torque arm setup.
Setup was a 99 camaro SS
-Stock 10-bolt, TA cover, welded axle tubes, auburn diff, 3.42 gear
-TH350 3000 stall
-LQ4 Cam only + 200 shot plate out the hole
-275/50/15 MT Drag Radial
Old 10-14-2009, 09:07 AM
STEEPSS's Avatar
i went SEVERAL passes @ a 1.62 sixty. Went ahead and swapped it out before it broke though. I don't like gettin stranded.
Old 10-19-2009, 05:43 PM
MASS seller approved
smok'nZ's Avatar
did you ever run a 150 on it?
Old 10-19-2009, 11:46 PM
RedsrtAk's Avatar
Holy crap....and I thought I was moving out on the stock 10 bolt. Good runs. That's even more impressive with the stock TQ Arm too.
Old 10-20-2009, 06:29 AM
blackfang's Avatar
I believe from the text I got, Ray went 10.08 at the LSx Shootout still on a stock 10 bolt.
Quick Reply: 10.28 @ 134 1.53 60'.... Who says you can't get down on a 10 bolt...
