10 Second Club Now you are haulin! 10s are sweet
6.0 lq4
Old Sep 9, 2013 | 04:16 PM
onefast84's Avatar
Default 6.0 lq4
Ran a best of 10.40 spinning like crazy! I know its got 9s in it, but the track prep was bad.
Old Sep 9, 2013 | 04:19 PM
HCI2000SS's Avatar
Very nice! What do you make for power? Did you run Milan?
Old Sep 9, 2013 | 04:25 PM
onefast84's Avatar
Its never been dynoed. Probly around 550-600 at the flywheel plus a rich 180 shot. I can get the pic of the timeslip to load
Old Sep 9, 2013 | 04:27 PM
HCI2000SS's Avatar
Cool! I just realized i'm not to far from you. I'm in the Howell area my self
onefast84's Avatar
And I went to stanton. I think that I would have better luck at Milan. 60s were like 1.7s, **** they were 1.5s on motor.
Old Sep 9, 2013 | 04:31 PM
speedtigger's Avatar
Old School Heavy
How did that 4200 converter like the nitrous?
Old Sep 9, 2013 | 07:17 PM
onefast84's Avatar
It hit the tires pretty hard, and brew them loose. Had to pedal it, and it still spun before it hooked.
Old Sep 9, 2013 | 07:47 PM
Old School Heavy
I was just curious to see if it was slipping with that size shot. You running a 73n jet in the nitrous?
Old Sep 10, 2013 | 06:31 AM
onefast84's Avatar
Yup on the 73n stil 73 on fuel too. If I get it to hook I can lean it out a bit.
Old Sep 10, 2013 | 09:14 AM
onefast84's Avatar
https://ls1tech.com/forums/picture.p...ctureid=104401
Maybe this will work for the timeslip. Right lane 1700m
Old Sep 10, 2013 | 10:56 AM
Old School Heavy
The difference between my 10.20s and your 10.60s is mostly all before the 330' mark. You get that thing launched and you will be right there.
Old Sep 10, 2013 | 05:46 PM
onefast84's Avatar
Oh yea it went 11.14 on motor, and launching good. I could use a bigger carb. An 825 Demon just cant build power on the top side!
Old Sep 10, 2013 | 08:29 PM
Old School Heavy
What was your MPH on the motor?
Old Sep 11, 2013 | 07:38 AM
onefast84's Avatar
121 mph
Old Sep 11, 2013 | 09:16 AM
Old School Heavy
121 mph
So you are picking up 9 mph on a 73n jet and I typically pick up 11 to 12 on a 63n jet. I bet I am a lot less aerodynamic too. Makes me think your converter is slipping pretty hard on the nitrous.
Old Sep 11, 2013 | 09:41 AM
onefast84's Avatar
Yea I am using a lot of mismatched parts. Carb, efi cam, and trans/converter. Its pretty much got a jumkyard trans in it with a valve body too. It doesn't build much power above 5500-6000. So I plan on some upgrades over the winter to the engine, trans, and suspension.
Old Sep 11, 2013 | 09:43 AM
onefast84's Avatar
What fuel jet with that 63n?
Old Sep 11, 2013 | 10:21 AM
Old School Heavy
I currently have 63n/51f in the car. The plugs look great. I pulled 6 degrees but the timing mark on the plugs look like I could at a degree or two back in. Also the fuel shadow is darker than it might be because I drove it back to the pits. I hate pulling plugs out of a hot motor.
Old Sep 11, 2013 | 11:02 AM
onefast84's Avatar
I am running a 73 in oth with 5 psi fuel and only 6 lbs in a 85* bottle. Not sure on the bottle pressure as my gauge had to be unhooked, because I had a small leak in the hose. A local 1/8 mile track just reopened after 35 years of being closed. So I want to go and do some more testing.
Old Sep 11, 2013 | 03:50 PM
onefast84's Avatar
Do they have some cruise nights in howell?
