SBE ls1 t56 broke 10s!
i already posted the slip awhile ago when it happened, but here's the video. I figured I'd share this pass and a little backstory. I took my cam, fast 102, bolt on Camaro to the track, it weighed in at like 3450 with me in it, made roughly 438whp, and with a 9'' rear I took it to the track, and managed an 11.97 at like 116. I went home, and over the course of of a year i swapped to tfs220 heads, btr4 cam, and took some weight out. After a few rentals and figuring out how to drive the car at a track, and what worked best, I finally went 10s. Ran a bunch of 11.0s also, which was frustrating. Best pass was 10.93 @127, 1.56 60ft, 7.0 1/8 @ 97. car has trapped as high as 128.8, and had a better 60ft. The whole set up is changing, but I think that i could knock more time off if I frequented the track more!
MASS seller approved
Should be able to go quicker ets with 128 trap speeds. Are 220 heads as cast or touched up. Brian Tooley is known to touch up. If on a budget, you can get you a drill and some sand porting rolls and just smooth out ports and remove any casting flash for better flow. Could do same to Fast 102 intake. CONGRATS ON 10s.
