Fbody Camaro (427 LS3/Manual trans) NEW personal best at the drag strip
You'll also have to check the pinon angle for the torque arm too. If everything else was adjusted except for that then that would must likely be the issue.
Cool, a torque arm adjustment thread for getting a better 60'
https://ls1tech.com/forums/drag-raci...djustment.html
Hope these help!
Hope these help!
I remember I raised my front ride height up and made a big difference. If I remember right I raised it a inch, so measured in the center of the wheel, from ground to fender lip was 27 inches. Front came up better and stayed up. Strange single adjustables up front.
