10 Second Club Now you are haulin! 10s are sweet
Fbody Camaro (427 LS3/Manual trans) NEW personal best at the drag strip
Old Feb 28, 2022 | 01:33 PM
LaBLKv6Z's Avatar
Arrow Fbody Camaro (427 LS3/Manual trans) NEW personal best at the drag strip
Mods list:
T-ROD MOD LS3 intake manifold (done by myself)
LS3 block- 4.070" bore Manley 4340 Forged Steel 4.100" Crank
SCAT 6.125" I-Beam rods
Manley 2618 Forged -7cc flat top pistions
GM oil pump
Ported (by myself) 821 heads
Stock GM replacement valves (hollow intake)
BTR dual platinum springs .660" lift with steel retainers
Johnson reduced travel race lifters 2116LSR
TSP Cam 243/255 .621/.619 111 LSA
TSP 2"primary to 3.5" collector long tube headers
Meziere 300 Series Electric water pump
92 MM TB
Siemen Deka 80lb injectors,
LS3 fuel rail
These are the latest runs on my current setup and getting more into the 10's. The car weighs approximately 3560lbs with me in it currently. Sadly I didn't get a slip on probably one of my best runs (lifted the front tires off of the ground).
Old Feb 28, 2022 | 03:44 PM
handyandy497's Avatar
I ran Hoosier 28" 295/50/16 dr's/Moser 9" 4.10's and a Yank 4000 stalled A4. Tires up and no spin at all on not so good prep. 98 T/A 418 ls2 4.1 stroke Gmpp ls3 heads, stock intake Fast 92 tb. 235/250 113+4, LT Moral lifters. Same weight!
Old Mar 1, 2022 | 12:56 AM
LaBLKv6Z's Avatar
Very Nice! What was your trap speed in the 1/4 on that run?
Old Mar 1, 2022 | 02:40 PM
30th t/a's Avatar
That trap speed is impressive. Get that 60' down and you got easy mid 10s. What was the DA?
Old Mar 1, 2022 | 03:44 PM
That was my only run. It was a 1/8 mile track here in F.L. They told me to at least put on a fire jacket and to not where shorts. lol. It gets warm here in April. I'm close to done with a 426 ls3 build. I have been scratching my head on what intake to use. I bought a lsxr with medium runners but most guys here like the Holly Sniper better. I found that BTR now makes a ls3 Trinity good for 8000 rpm that fits under my hood. My roller cam is spect to rev @ 7600 rpm so I'm going to order one, Between the two intakes Ill keep the one with the best mph and or 60ft time. The other will go in my 08 Vette vert. Hopefully the Vette will get the Fast so I can switch the runners for less rpm. The Vette will get the 418 cam. Short travel Morel (BULLLET) lifters, Gmpp ported heads and a Yank too. Yank said they had the same c-6 corvette over there with one in it and ran like stock but can pull 1.5 60ft's on dr's. Paddle shift 6L80 2.56 gears! If that works I might leave the stock cam with the short travel lifters in it for maybe 10's and 30+MPG.
If you can send me any info on those Siemen Deka 80's for the computer I'll buy a set. What pump are you using? The 418 was using ls3 injectors with a 380 Walbro pump. Injectors were at 100% DS at 7200rpm 1 to 2nd shift and liked it. Yikes!
Old Mar 1, 2022 | 10:40 PM
LaBLKv6Z's Avatar
Appreciate it, DA was -360 to -400.
Old Mar 1, 2022 | 10:43 PM
LaBLKv6Z's Avatar
I'm still running a racetronix 255 with hot wire kit on 93oct. My rod modded intake manifold is holding it's own at 7k.
Check out post #10 for injector data below.
https://ls1tech.com/forums/pcm-diagn...base-tune.html
I bought the Greg Dash DVD for inj data and later found that the data is all over the internet.
Old Mar 31, 2022 | 04:58 PM
Roarin_8's Avatar
Hey you finally got a hood on the car! Just saw one of your vids and I'm thinking man, no hood anything can go flying in there.... Nice runs though!
Old Mar 31, 2022 | 09:22 PM
Zmg00camaross's Avatar
Nice runs fellow stick shift man.
Old Apr 1, 2022 | 06:27 AM
LaBLKv6Z's Avatar
Hell yeah, thanks man. It's been a few months with the new hood painted.
Thanks man
Old Apr 1, 2022 | 07:10 AM
madmike9396's Avatar
Getting that suspension dialed in will for sure net you some low 10s with that trap. she's cooking on the back side !
Old Apr 1, 2022 | 07:58 AM
Roarin_8's Avatar
Yup I was thinking with a 1.3 60' that's 10.0 there with that 131 trap.
Old Apr 1, 2022 | 08:07 AM
Roarin_8's Avatar
That should be around 121-125 mph in the 1/4 with an 10.9-11.0 ET
Old Apr 1, 2022 | 08:15 AM
LaBLKv6Z's Avatar
I think I'll need to step it up and get the double adjustable front shocks. The singles are working okay but the front moves a bit between shifts.
Yeah the 60' needs improving tremendously! Last time out I was averaging over 132mph with A/C and heavy T/A powered seats, along with my full size front tires lol
Old Apr 1, 2022 | 08:40 AM
Roarin_8's Avatar
What kind of tires are you running on the rear?
Old Apr 1, 2022 | 09:52 AM
LaBLKv6Z's Avatar
Hoosier QTP 27-11.5/15 bias plys
Old Apr 1, 2022 | 10:40 AM
Roarin_8's Avatar
Tires aren't the problem then, how does the suspension look?
Old Apr 1, 2022 | 11:42 AM
LaBLKv6Z's Avatar
Front:
Strange single adjustable coil overs, 300lbs springs
UMI tubular adjustable upper and lower control arms
Rear:
Comp Engineering 3 way shocks
Springs-Vogland springs in the begin runs of the vid and stockers in the end runs
Founders tubular control arms, panhardbar
UMI adjustable torque arm
Old Apr 1, 2022 | 01:32 PM
Roarin_8's Avatar
Front:
Rear:
Car is lowered too right? If so, then yeah you'll need to make adjustments to have the rear end squat better.
Maybe some tips in here can help: https://ls1tech.com/forums/drag-raci...est-60-ft.html
Old Apr 1, 2022 | 01:52 PM
LaBLKv6Z's Avatar
Yeah, so in the video you can see I lifted the rear up a bit when the stock springs were added to the rear. I started with a ton of anti squat and then added a lot of squat via springs and rear lca angle lol
