10.88 S.I. dry shot
10.88 S.I. dry shot
Sorry about the picture being so large. I included the 11.014 slip because i have a video of it so i can back up the 10.88 slip. The printer was messed up that day at norwalk. This was the day Harlan made his debut passes with his car. I guess i could PM Derty and have him verify the printer was bad that day. The 8 look like 0 but if you look closely you can see the 0 are rounded off at the top. The mods are in the sig. 104 unleaded race gas with a 10.8 to 11.1 A/F. I ran a 2 stage dry shot with no jets in either stage that day. I burned over 10#'s of nitrous in 4 passes from my 15# bottle. had to take my air cleaner out. the humidity was so high I saw it looked like it was raining in my clear lid and my air cleaner was soaked. 15x28x10.5 et drags with et skinnies and convo pro's. I had been hovering in the low 11's all year using the stock rims and et streets. then i went to the convo pro's and the drag tires went from poly poly LCA's to poly rod adjustables and relocation brackets and pulled the jets out and finally got a 10. have been working to much since will try and sneek off to the track again soon.
