Can these mods net me 10's with street manners?
Should this list below get me into the 10's? Thanks, Brian Kaiser
LMSSRA Super Sucker Ram Air Kit:
$199.99 1 $199.99
SLP21044 SLP INDUCTION LID 98-99 MODELS :
$94.99 1 $94.99
GRN9885 F-body 85mm MAF meter :
$149.99 1 $149.99
EXP198 PORTED STOCK THROTTLE BODY, EXCHANGE :
$129.99 1 $129.99
GM88890524-B Z06 INTAKE W/EGR MODIFICATION :
$465.99 1 $465.99
PS72C2253 Pace Setter 98-99 Long Tube Headers COATED:
$399.99 1 $399.99
QTEC30CP Quick Time Electric Cutout and Flowtech Cutout 3" Package:
$174.99 1 $174.99
IZM993-2ext O2 SIMULATORS, PAIR, WITH OTHER EXHAUST PURCHASE :
$79.99 1 $79.99
IZM9243 24" O2 SENSOR EXTENSION HARNESS :
$17.99 1 $17.99
PS82-1163 Pace Setter 98-02 LS1 Off-Road Y-pipe for PS LT Headers:
$124.99 1 $124.99
HYP1014 HYPERTECH 160 POWERSTAT W/HOUSING :
$46.99 1 $46.99
MEZWP319R Meziere electric water pump (red):
$569.99 1 $569.99
SC094 STAR Stage 4 Clutch :
$439.99 1 $439.99
SC75S Gm High Carbon billet flywheel (addon to clutch):
$199.99 1 $199.99
SUB1094S HD STEEL NITROUS SHAFT custom length:
$389.99 1 $389.99
CC7955-16 CHROME MOLY PUSHRODS 7.400 - STOCK LENGTH:
$114.99 1 $114.99
CC26921-KIT Comp LS1 26921 Spring Kit - Dual Springs with seats-retainers-seals:
$559.99 1 $559.99
LUN-55008 Lunati 237/242:
$379.99 1 $379.99
RM1160 Rollmaster Double-Roller Adjustable Timing Set, Heat-Treated, LS1-Based Cars and Trucks:
$118.99 1 $118.99
SLP55001 SLP Heavy Duty Oil Pump:
$159.99 1 $159.99
ASP948584 CRANK & ALTERNATOR PULLEY SET :
$209.99 1 $209.99
MOS293 DIRECT REPLACEMENT 9" WITH EATON POSI :
$2,169.99 1 $2,169.99
MOS101 FOR FUNCTIONAL ABS AND/OR TCS:
$100.00 1 $100.00
HAL193R COMPLETE PACKAGE DEAL INCLUDING A SET OF SPRINGS, R SHOCKS AND WRENCH :
$709.99 1 $709.99
AA003 SET OF UPPER & LOWER A-ARMS-complete set :
$549.99 1 $549.99
STB001 2 POINT STRUT TOWER BRACE :
$89.99 1 $89.99
MCA002 CHROME MOLY ADJUSTABLE CONTROL ARMS-poly bushings :
$149.99 1 $149.99
PHR001 TUBULAR PANHARD BAR-polyurethane bushings :
$89.99 1 $89.99
XTA001 XTREME DUTY TORQUE ARM :
$549.99 1 $549.99
KBP-19304 Double Diamond Subframe Connectors for GM F-body 98 -02 :
$239.99 1 $239.99
DSL001 DIRECT BOLT-IN DRIVESHAFT LOOP :
$99.99 1 $99.99
DTB001 BOLT-IN TUNNEL BRACE :
$89.99 1 $89.99
FWOL320 5-Point Bolt-in Roll Bar, Powder-coated Black:
$499.99 1 $499.99
BRE1237005A2 BREMBO BRAKE PACKAGE RED CAILPERS :
$2,949.99 1 $2,949.99
PIAA19606 PIAA Platnium Super White Low Bean (twin pack):
$69.99 1 $69.99
PIAA19605 PIAA Platnium Super White High Bean (twin pack):
$69.99 1 $69.99
NR3175 Day[WHITE W/BLACK NUMBERS]
Night [BLACK W/BLUE & WHITE NUMBERS]:
$124.99 1 $124.99
Sub-Total does not include shipping charges or taxes
Sub Total $13,584.64
Alot of money but i just want to know what i need to work at. Thanks
$199.99 1 $199.99
$94.99 1 $94.99
$149.99 1 $149.99
$129.99 1 $129.99
$465.99 1 $465.99
$399.99 1 $399.99
$174.99 1 $174.99
$79.99 1 $79.99
$17.99 1 $17.99
$124.99 1 $124.99
$46.99 1 $46.99
$569.99 1 $569.99
$439.99 1 $439.99
$199.99 1 $199.99
$389.99 1 $389.99
$114.99 1 $114.99
$559.99 1 $559.99
$379.99 1 $379.99
$118.99 1 $118.99
$159.99 1 $159.99
$209.99 1 $209.99
$100.00 1 $100.00
$709.99 1 $709.99
$549.99 1 $549.99
$89.99 1 $89.99
$149.99 1 $149.99
$89.99 1 $89.99
$549.99 1 $549.99
$239.99 1 $239.99
$99.99 1 $99.99
$89.99 1 $89.99
$499.99 1 $499.99
$69.99 1 $69.99
$69.99 1 $69.99
$124.99 1 $124.99
That shopping list is a little much (the headlights won't get you 10's, neither will the brakes). Looks like a mid/high 11 second list for most cars. Without tires (slicks) and weight reduction, I'd say no chance.
Stuff like strut tower braces do nothing for drag racing except add weight. You'll also need computer tuning ($500), and make sure the panhard is adjustable (so you can center the rear).
its an overall list of items i want to buy....not just drag racing. I want great handling and decently fast 1/4 mile times. I may throw on a 100 shot or so. Thanks, Brian Kaiser
Sweet Cheeks
Don't waste your money on Brembos. I'd go with replacement rotors and a nice pad setup if you're street-driving the car. With the extra $2,000 you're not using. Put it into some sort of savings accout, you'll need it later. Trust me.
Yeah, you really need too look and learn a whole lot about the parts you are buying.
You can spend 20k in parts and still have a 12 second car. Its all about buying parts that work together well, and making them do so.
If your looking at spending some serious cash and dont have the time/desire to learn about what will work best for the car, Give one of the sponsors a call, tell them what you have to spend and what you want out of the car and they can hook you up with what all you will need and work the best.
Also Street Manners is relative, if you car is stock now, no it wont feel like stock when your done, but if you are a little on the hardcore side you should be able to deal with it fine on the street.
