10 Second Club Now you are haulin! 10s are sweet
How are you 6 speed guys leaving???
Old Apr 3, 2005 | 04:06 PM
gwcrim's Avatar
I'm wondering what the pressure plate set ups are like.
Old Apr 8, 2005 | 10:21 PM
ITLstallion04's Avatar
I leave off the limiter, or if i leave on juice, about 4200, set it for 4500.
Old Apr 10, 2005 | 05:49 PM
SMOKIN01TA's Avatar
Originally Posted by kurt crosbie
SMOKIN01TA,
Did you run that 10.43 on the spray?? Only 442rwhp! Holy ****! I seriously need some head work.
I'm not sure what I'm running right now, but I'm pushing ~390rwhp.
what have you dropped from your car to get down to 3000lbs?
nope, i have no spray or head work. that was just a cam in a stock shortblock with stock 241 heads, 90mm intake and 3150car. now im lighter and think i can manage a lil better since droping another 200lbs
Old Apr 11, 2005 | 12:32 AM
sardog46's Avatar
i uselly leave with the two step set on 6500 for motor and 6000 witha 100 shot. This is on a 28" tire with 4.10's
Old Apr 11, 2005 | 03:31 PM
v8maro's Avatar
What kind of clutches you guys running???
Old Apr 11, 2005 | 05:48 PM
sardog46's Avatar
SPec 3I
Old Apr 11, 2005 | 06:00 PM
SMOKIN01TA's Avatar
spec 4
Old Apr 13, 2005 | 09:24 PM
SPEC stage 3, Aluminum flywheel.
Old Apr 21, 2005 | 07:21 PM
97SprChrgd383's Avatar
Anyone have a supercharged stroked 383 setup? My block is completely forged(crank, rods, chrome moly pushrods,).I've got that setup being built right now with qa1 coil overs in front w/ bmr tubular k-member, tubular upper and lower a arms, and qa1's in rear 12 way adustable all the way around. Moser 9" rear end with 33 spline axles and srange heavy duty posi with 3.55s. I will be pushing 15lbs of boost w/ my intercooled procharger. Any idea's on what u think my 1/4 time will be? Seeing the 450hp going 10's is impressive.
Old Apr 21, 2005 | 07:25 PM
Oh, I also have a viper t56 setup with mcleod twin dual disk. Opinions?
