10 Second Club Now you are haulin! 10s are sweet
How are you 6 speed guys leaving???
Old Jan 31, 2005 | 08:53 PM
99HUGGSS's Avatar
Default How are you 6 speed guys leaving???
I just got my suspension done and I need some advice about how to get my pig off the line. I have a complete chromoly tubular setup up front, k-member and all. Qa1's all the way around with drag springs up front. I am running Hoosier QTP's 27x11.5x15's out back and skinnies up front. Should I leave on the limiter or should I try lower RPM's? I want a killer 60' and I would like to get a high 10 on motor, I would think that would be possible with a 3400 race weight and 450 at the wheels? Any suggestions on how to leave and what I should set my shocks at? TIA!!!!
Old Feb 1, 2005 | 04:08 PM
99HUGGSS's Avatar
anyone???
Old Feb 1, 2005 | 06:51 PM
Jonathan@Tick's Avatar
LS1TECH Sponsor
Last year I tried to leave the line at 6500 rpm , my rev limiter is set at 7000. If the track wasn't quite right, it would spin just a little and turn a 1.60 60 ft. If it hooked, it was around a 1.52 60. My moser 12 bolts gear only lasted about four trips to the strip, before it started making the most horrible roaring sound ever. I replaced the gear and the posi with a spool, but haven't had a cance to run it yet. The spool sucks for the street though. I would leave around 6000 or so, as long as there is traction.
Old Feb 1, 2005 | 06:56 PM
LS1TECH Sponsor
Oh yeah, I set the front qa1's on the #2 setting for the track, I hear some people run them on the first setting or "full loose". I'm running comp engineering shocks on the rear.
Old Feb 1, 2005 | 07:28 PM
SMOKIN01TA's Avatar
with 450 at the wheels 10 will not be a problem if you can get it to hook
i leave a 6200 on slicks with front hals on 3 and rears on 4. 2 in the front is too bouncy when the tires set back down. my drag bar has no preload one way or the other in the rear and leaves straight as a arrow and perfectly level now. best 60 was a 1.431
Old Feb 1, 2005 | 07:36 PM
Slow Z28's Avatar
I'm with SMOKIN...
I was same range, same setup on the HALS all the way around, and funny thing, same setup on the Wolfe rear bar. straight as an arrow to 1.4's. Going to a TH400/TH350 setup this year cause I can't drive/shift
Old Feb 1, 2005 | 07:47 PM
SilverGhost's Avatar
Motorboater
when i went 11.0..**** i can't for the life of me rememer my shock settings right now but i was dumping the clutch at 7,000-7,200 rpm. that was normal. i think i'm gonna try less rpm first time out next year. 1.51's were norm for 60 foot.
Old Feb 1, 2005 | 09:22 PM
smokeum99ta's Avatar
6000 and eat'r eat.qa1 all around .front on 4 rear on 5 is the only way I can leave straight.low 1.50's consistenly.
Old Feb 1, 2005 | 10:24 PM
99HUGGSS's Avatar
thanks guys, I'm going to the track sunday....... wish me luck
Old Feb 2, 2005 | 12:12 AM
SMOKIN01TA's Avatar
id have to make a pass on the spray if i was you just to get a 9 sec slip in my pocket
Old Feb 2, 2005 | 08:57 PM
99HUGGSS's Avatar
I think our DA up here is around +800, doubt I could hit 9's with my current setup. I'm thinkin' 10.20's on the 150's
Old Feb 3, 2005 | 09:33 AM
SMOKIN01TA's Avatar
you know how to find out
Old Feb 3, 2005 | 11:39 AM
99HUGGSS's Avatar
yea, sunday will be the day!!!!! Wish me luck
Old Feb 7, 2005 | 01:14 PM
mike#9's Avatar
So what did you run?
Old Feb 7, 2005 | 04:22 PM
99HUGGSS's Avatar
We got rained out, I'm goin' back this weekend
Old Feb 12, 2005 | 05:33 PM
5w20's Avatar
how did it go? or is it tomorrow?
Old Feb 14, 2005 | 08:30 AM
99HUGGSS's Avatar
I went 10.91@128 with a 1.61 60'
the track prep left a little to be desired, a few more times and there should be some good rubber down.
Old Mar 21, 2005 | 08:35 PM
02SOMWS6's Avatar
I have yet to go as quick as you but I have pulled a 1.56 60ft with stock shocks and springs on a 26" tire.
Old Mar 22, 2005 | 03:46 PM
kurt crosbie's Avatar
SMOKIN01TA,
Did you run that 10.43 on the spray?? Only 442rwhp! Holy ****! I seriously need some head work.
I'm not sure what I'm running right now, but I'm pushing ~390rwhp.
what have you dropped from your car to get down to 3000lbs?
Old Apr 3, 2005 | 03:13 PM
nikejr16's Avatar
Holy geezas batman 7,000-7,200 rpm dumps. how stuff have you've broken?
